Author Topic: Reflex Nikkor 500/8 N on Zf  (Read 4085 times)
« on: October 08, 2024, 22:54:56 »
Obviously, the stabilizer helps, although the image still feels shaky in the absence of any monopod. Foolish me, I thought I could spare it. Focussing is much safer than when using the Df, thanks to focus peaking or magnifier.
As for the results, they are a matter of taste.
Re: Reflex Nikkor 500/8 N on Zf
« Reply #1 on: October 08, 2024, 22:57:11 »
... some more, still botanical or mineral:
« Reply #2 on: October 08, 2024, 22:58:19 »
... and, finally, with humans (all were shot in downtown Lille). Please note that the seemingly B&W ones are actually color photos. No desaturation was involved. Sad, isn't it?
Gerhard2006
« Reply #3 on: October 08, 2024, 23:23:53 »
Wow what a sharp lens. I owned the 1000mm F11 and always had owls with fuzzy eyeballs because of mirror slap on my Nikon FE. These lenses work best at 20-50 feet but at distant subjects they compress ultra violet light which kills sharpness. Although the flower shot looks great. These pix look great and don’t show the donut shaped bokeh balls except the last shot. Thanks for sharing. Regards Gerry
« Reply #4 on: October 08, 2024, 23:43:10 »
I do not quite understand "compress UV light"; could you elaborate? I did notice some phenomena such as a central "hot spot" or a general low contrast, but UV is not necessarily the cause.
Concerning the donut bokeh: it is seldom pleasant, although it happens (see e.g. the "boiling bush" shot I posted somewhere here). Today, I however made use of foreground bokeh more often than background bokeh, and it looks more "plastic".
« Reply #5 on: October 09, 2024, 00:16:45 »
There doesn't seem to be any negative side of the reflex lens here.  The characteristic ring bokeh is effectively utilized, at least to my eyes.
I particularly like the "Westfirled" and "Café de Paris".
Jürgen Pfeiffer
  • You ARE NikonGear'23
« Reply #6 on: October 09, 2024, 12:13:15 »
And it's very easy to glue a Dandelion chip to the 500mm Reflex. This way also the eye detection works with Zf. On this camera the Reflex is very useable, on a DSLR decent pictures were very hard to obtain.
But – don't get your hands on a Z Nikkor 400/4.5. You will be lost :)
(tree leopard with Zf and 500mm Reflex new)
Jürgen Pfeiffer
« Reply #7 on: October 09, 2024, 12:24:41 »
Great shot. Who can provide the chipping?
Jürgen Pfeiffer
« Reply #8 on: October 09, 2024, 13:01:49 »
It is a Dandelion chip, just glued to the Reflex with the rear filter removed. I bought them from Andrey Kuryanov's ebay shop (search for Dandelion chip).
Jürgen Pfeiffer
Gerhard2006
« Reply #9 on: October 18, 2024, 20:27:08 »
When you shoot distant subjects the ultra violet that comes off the land is compressed by the telephoto effect of the lens and the picture comes off looking very cold white balance on film. On digital cameras it’s easily corrected in post or other shade preset. I just remember getting landscape shots back in the film days with a blue overcast. If you do a Google search on compression of ultraviolet light on long lenses it is an interesting phenomenon that happens from 500mm and up
Snoogly
  • Flipping the bird
« Reply #10 on: October 19, 2024, 03:51:39 »
I glued the chip to the filter, then I have an easy way to switch between a chipped and unchipped lens.
Snoogly
  • Flipping the bird
« Reply #11 on: October 19, 2024, 04:09:34 »
Oh, and with the chip does IBIS work properly? With the camera body really recognizing it as 500mm?
« Reply #12 on: October 19, 2024, 12:11:47 »
You'd expect the IBIS to work even without chip, as is and was the case with Olympus m43 cameras. Accelerations are measured on the camera body and image displacement is measured on the camera sensor, so the lens is not involved in the immediate inputs, and the FL is about tuning the feedback loop. Setting the FL manually is sufficient to "tune" the IBIS on Olympus cameras. I'll check the behaviour of the Zf (so far I only shot pics, not bothering to study the animal).
« Reply #13 on: October 19, 2024, 12:13:52 »
... the rear filter? makes me wonder how all of this is wired...
Snoogly
  • Flipping the bird
« Reply #14 on: October 19, 2024, 18:46:28 »
IBIS is easily set for non cpu lenses, but chipped lenses are at the mercy of how the chip plays with IBIS. I am pretty sure I heard that Dandelion chips can’t pass accurate IBIS info.
