Author Topic: X-T3 failure  (Read 2673 times)
X-T3 failure
« on: July 11, 2024, 16:43:55 »
The front control wheel in my X-T3 is failing, when I try to adjust the aperture of lenses without the aperture ring, it gives ramdom values unless i turn it really slow
A bit frustrating
I located a repair shop that has dealt with the same problem in other x-t3 cameras
A spare control unit has been ordered, it costs about $170 dollars
Will have to add the workmanship on top of that , once the spare part has been recieved the turn aroud  time is expected to be a couple of days
This is my first time ever sending any photo equipment to be repaired , if everything goes well my D800 is in need of some love , plus the 70-300 zoom and a couple of flashes
This is the failing wheel
Re: X-T3 failure
« Reply #1 on: July 11, 2024, 20:34:03 »
Must be a worn-out bearing or similar inside.
Re: X-T3 failure
« Reply #2 on: July 12, 2024, 00:24:35 »
If I remember correctly, the dial also functions as a push switch.  Your X-T3 should have served you for quite a long time, and frankly it is not surprising that the part is worn out.  Hope the repair to go well.
Dogman
Re: X-T3 failure
« Reply #3 on: July 13, 2024, 16:18:43 »
I rediscovered an old X-T1 recently and found I could tolerate the EVF so I started using it again.  It has the same issue with the front wheel--intermittently.  Since all my lenses have aperture rings and the other functions of the wheel are not really important to me, I just ignore it.  But, of course, ignoring it is not an option in your case.
