Hello all
I picked up a 50mm f/1.8AIS long nose with a little fungus and dust. I am aware, thanks to Richard Haw's site
https://richardhaw.com/2020/05/30/repair-nikkor-50mm-f-1-8-ai-s-long-nose/, on how to access to the front elements but one of the bayonet screws has been stripped so can't remove the mount. I am wondering if anyone has experience of removing the entire optical assembly, INCLUDING the aperture and rear lens block via the front and whether I will face issues re-inserting and realigning the aperture ring coupling and bayonet aperture activation lever?
(c) Richard Haw
The hole at the 3oclock position is where i suspect the aperture activation lever will need to slot through and without the bayonet removed, i dont know how easy it will be to realign everything "blind". I have serviced a number of my other AI/AIS lenses and some I recall can slide out (maybe the 24mm f/2.8AI?) and reinserting is not too painful.
WIth this specific lens, I have also found with the front optical block removed, unscrewing the front retaining ring for access to front element is impossible - even with acetone and IPA around the base and using rubber grips and even plumber's grips I can't unscrew it! I worry that the back retaining ring will also be equally well sealed and want to know what else I can try. If access to rear elements is only available from rear, what if any are my best options to remove the rear retaining ring or should i look to remove the stripped bayonet screw (and how?)
The lens is producing really nice images (a nice surprise) so I'd hate for the fungus to grow and destroy it.
