Author Topic: November 2023  (Read 71376 times)
Re: November 2023
« Reply #30 on: November 02, 2023, 06:19:24 »
For a batch of 4 different percentages of best frames it can take hours to stack a single Jupiter take of that length (maximum of about 3 minutes length to avoid rotation blur), depending on how large the imaging area has been set. I can just start it before going to sleep or let it work in the background while doing other things. BTW I replaced it with another stack of the same take with less noise and better alignment on the moons.
Re: November 2023
« Reply #31 on: November 02, 2023, 06:28:11 »
Thank you, again, for the details.  That it took hours is not really surprising.  I'm looking for more to come!
Re: November 2023
« Reply #32 on: November 02, 2023, 07:29:17 »
My museum work begins to show ... here is a part of what I have done the last months. Each herbarium box contains up to 200 collection sheets of pressed material, and each sheet therein has to be checked and verified.
Now that I have reached the ceiling -- literally -- I might take a break? Or continue to build another tower :)
The towering tower
Re: November 2023
« Reply #33 on: November 02, 2023, 09:30:06 »
November 2
'chasing skies'
Zfc 16-50mm f/3.5-6.3
Re: November 2023
« Reply #34 on: November 02, 2023, 10:49:28 »
Lille, the edgy Casino.
Zf, 50/1.8 S @5.6
Re: November 2023
« Reply #35 on: November 02, 2023, 20:45:32 »
Testing the re-introduced Gallery feature,
Blue Bridge
It works :) :)
Re: November 2023
« Reply #36 on: November 02, 2023, 20:59:47 »
Windy
Re: November 2023
« Reply #37 on: November 02, 2023, 23:38:31 »
Late hour power.
  D5, 70-300mm 4.5-5.6 vr  The combo really well with sharpness at low shutter speeds and high iso needed to capture this. 2 images vertical pano composition to get the full image.
Re: November 2023
« Reply #38 on: November 03, 2023, 07:04:05 »
Zf, 50/1.8 S @5.6
Looks like it was shot with 28/3.5 PC...
Re: November 2023
« Reply #39 on: November 03, 2023, 09:23:05 »
Actually, not. Not even perspective manipulation. I only cropped the pic to 3:4 ratio. The architect did the trick.
Re: November 2023
« Reply #40 on: November 03, 2023, 12:03:45 »
Darkness prevails
Re: November 2023
« Reply #41 on: November 03, 2023, 15:19:52 »
Oh, I just noticed the trick.  Wow!
Re: November 2023
« Reply #42 on: November 03, 2023, 15:20:43 »
Replay.
Re: November 2023
« Reply #43 on: November 03, 2023, 18:54:48 »
November 3
fire in the sky
Z fc, 16-50mm f/3.5-6.3
Re: November 2023
« Reply #44 on: November 03, 2023, 23:45:52 »
Mediterranean pine clouds
Yes!
