Author Topic: Plena?  (Read 24034 times)
Re: Plena?
« Reply #120 on: December 09, 2023, 05:34:57 »
The neo noct is my favourite portrait lens on the D500,,, a very great lens on FX too
58mm is the perfect focal length for the portraits on APS-C format, too.
Wally
  • X-Man breaking bad
Re: Plena?
« Reply #121 on: December 10, 2023, 03:11:08 »
Here is the direct comparison with the 105mm/1.4E
100% crop, top right corner. 1/100 sec, f1.8
Re: Plena?
« Reply #122 on: December 11, 2023, 10:23:56 »
Thank you! That is an unexpected big difference in bokeh ball size! I guess that the 105mm would have to be wide open to get close?
ISO is 2200 and 3200 so not equal
Wally
Re: Plena?
« Reply #123 on: December 11, 2023, 22:15:57 »
Thanks Erik. I actually believe the ISO difference is of no importance here. Higher grain should actually smoothen the appearance.
Here is the f/1.4 vs f/1.8 of the 105mm/1.4E, minimal improvement IMHO. Maybe slightly rounder, better defined cat eyes...
Re: Plena?
« Reply #124 on: December 11, 2023, 22:25:03 »
I would still like some discussion of the Plena lens if there could be some.
Wally
Re: Plena?
« Reply #125 on: December 12, 2023, 02:20:11 »
Certainly Michael. Bokeh is only one aspect, certainly a big step forward. Even the comparison to high end, fairly recent F glass is astonishing. Let's keep in mind that this lens is very new, not many units have been shipped. Not many users have acquired it yet due to its speciality and elevated pricing. I got one since I received a very special deal on a used once copy, and because I am a Nikon nerd....
Re: Plena?
« Reply #126 on: December 12, 2023, 03:01:12 »
Well, what do you think of it?
Re: Plena?
« Reply #127 on: December 16, 2025, 18:54:47 »
personally I don't think the round disc is such important out of center(70%), and in real world it's a little complex of bokeh disc perfomance. with same lense but different angles and distance...
if the plena selling at 1500-2000USD that will make more sense
It does sell now for the price you requested: https://www.e-infin.com/eu/de/item/13641/nikon_nikkor_z_135_mm_f/1,8_s_plena_objektiv
Bernard Delley
Re: Plena?
« Reply #128 on: December 20, 2025, 10:59:22 »
The example comparison in Wally's post between the Plena 135 f/1.8  and the 105 f/1.4 is misleading, as the focus point is not well controlled. This has a great influence on the bokeh ball diameter.
If the back ground is at a fixed distance behind the sharp subject and the sharp main subject is imaged with the same magnification (or field of view in the sharp plane) , then  shorter focal lengths can emerge as producing larger bokeh balls than longer lenses. I have computed such a comparison in a thread at
https://www.dpreview.com/forums/threads/thoughts-about-bokeh-ball-diameter.4818228/
with apparent bokeh ball size referred to the plane of the sharp subject. (The constant imaging ratio of  1:15 refers my numbers given in that post to the ball diameter at the sensor. However, I find it more convenient to compare ball size to the photo motif size, thus my presentation)
Wally
Re: Plena?
« Reply #129 on: January 06, 2026, 16:08:56 »
Let me clarify that the focus point / plane was fully controlled. Camera on a tripod, focused on my car's license plate (outside of the crop). The only variable was changing the lenses.
While a simulation might add some findings (I am a scientist), I largely prefer real world comparisons for my photography and equipment choices. YMMV.
