Author Topic: So, the ZF ...  (Read 175232 times)
aerobat
Re: So, the ZF …
« Reply #195 on: October 22, 2023, 22:01:16 »
What we apparently see are the shutter blades. Not the shield structure of Z9 (and Z8).
Many thanks for the clarification Birna
Daniel Diggelmann
MILLIREHM
  • Vienna, Austria
Re: So, the ZF …
« Reply #196 on: October 22, 2023, 22:19:17 »
I missed the Z9-like shield. But as we have  (consequent for a camera like the Zf) a mechanical shutter still present, it probably would have been too much to have both. In default state the shutter is not visible, just the sensor
Wolfgang Rehm
Re: So, the ZF …
« Reply #197 on: October 22, 2023, 23:27:23 »
Are there different USB C profiles?
Isn't the MH-34 void of the actual charger which needs to be as an additional piece? I.e. it doesn't accept mains (AC) voltage, instead it requires a USB-C PD charger?
How cleverly the number of small pieces required in practice increases when the EU is trying to decrease it.
I mistyped it  ::)
There were Power Profiles (USB PD 1.0) which are now called Power Rules (USB PD 3.0) PD equals 'power delivery' Standards for USB.
Question is: does the charger need to be fed with more than 5 V or  15 W?
Re: So, the ZF …
« Reply #198 on: October 23, 2023, 09:55:21 »
I mistyped it  ::)
Nikon's EH-7P is said to supply 5 V and 3 A, max power 15 W. I would assume the AC adapter that Nikon sells is as capable as the camera can take advantage of. The PD charger I bought has a max power of 70 W or so, and it comes with two USB outputs, one USB-C and one USB-A. I guess the good thing is that I can use it to charge two devices at the same time, even if it is otherwise a bit overkill for my purposes. ;-)
aerobat
Re: So, the ZF …
« Reply #199 on: October 23, 2023, 17:51:10 »
today our guinea pigs were the guinea pigs for the Zf's AF - I like the results - Z 35mm @ f1.8
Daniel Diggelmann
aerobat
Re: So, the ZF …
« Reply #200 on: October 24, 2023, 20:23:18 »
trying some b&w - Zf & 35mm f/1.8
Daniel Diggelmann
Re: So, the ZF …
« Reply #201 on: October 24, 2023, 21:10:06 »
So nice.
aerobat
Re: So, the ZF …
« Reply #202 on: October 24, 2023, 21:47:56 »
Daniel Diggelmann
Re: So, the ZF ...
« Reply #203 on: October 26, 2023, 11:10:42 »
Outstanding! I love the rendering tonality and the picture itself ;)
Re: So, the ZF ...
« Reply #204 on: October 29, 2023, 10:09:30 »
A pity there is so long wait for the Zf back home :)
Bob Foster
Re: So, the ZF ...
« Reply #205 on: October 31, 2023, 02:48:57 »
Daniel,
What a human photo. A youngster learning a new skill; she's looking at the result, perhaps she sees that too much makeup doesn't give the effect she desires?
And yes, excellent mid tones, entirely appropriate for this image.
Bob
Re: So, the ZF …
« Reply #206 on: October 31, 2023, 14:12:56 »
  An instant classic. Lovely image. You are making a compelling case fo the zf  :)
aerobat
Re: So, the ZF ...
« Reply #207 on: October 31, 2023, 22:31:09 »
Many thanks Erik, Bob and Paco
Halloween - Zf & 35mm f/2.2; 1/125s; ISO 64'000 Lr denoise - AF was finding eyes where I struggled to see any...
I don't intend to shoot at such high ISO regularly but it's still impressive.
Daniel Diggelmann
aerobat
Re: So, the ZF ...
« Reply #208 on: November 02, 2023, 19:52:40 »
Doing homework can be cool ... at times  :)
Zf & 35mm f/1.8; 1/250s; ISO 2'800
Daniel Diggelmann
Re: So, the ZF ...
« Reply #209 on: November 02, 2023, 23:42:26 »
  It is impressive indeed, both the result and the af. Thanks for sharing it.
