Author Topic: Micro Nikkor AF 55mm f/2.8 lens on Nikon ES-2 accessory  (Read 3373 times)
olivierssd
Good morning,
I can no longer get my Nikon Super Coolscan 5000 ED slide scanner to work properly on my Windows 10 computer, due to a lack of adequate software. I tried Vuescan x64 but the results are not up to what I got on Windows Vista with the Nikon software.
I saw that there was an ES-2 accessory for scanning slides using the AF-S Micro NIKKOR 60mm f/2.8G ED lens attached to the D850.
I have a D850 and a Micro Nikkor AF 55mm f/2.8.
My question is: can I use the Micro Nikkor AF 55mm f/2.8 lens instead of the Micro NIKKOR 60mm f/2.8G ED lens. Has anyone tried this configuration and with what result?
The 2 lenses have the same filter mounting diameter : 62mm, so I will be able to mount the ES-2 accessory on the 55mm. But the 60mm is internally focused and the 55mm is not: does this difference have an impact on the use or the result?
Thank you in advance for your comments and responses.
(Excuse me for my broken English)
jborg
Re: Micro Nikkor AF 55mm f/2.8 lens on Nikon ES-2 accessory
« Reply #1 on: July 20, 2023, 20:33:04 »
I also am interested, having a D850 and a 55mm f/2.8, to know if ES-2 works "out of spec", and apparently it works according to this guy:
https://www.youtube.com/watch?v=oa-LVV1MDbk&t=1s
« Reply #2 on: July 21, 2023, 09:09:33 »
I can confirm the the ES-2 works well with the Micro 55/2.8 AiS lens + PK-13 extension tube (or equivalent extension tube) PLUS a 52mm to 62mm step up ring.  I don't have a 55/2.8 micro AF, so no knowledge about that one and the ES-2.
olivierssd
« Reply #4 on: July 21, 2023, 18:41:14 »
Hello JBorg,
Many thanks for the video link. It is very interesting because it demonstrates that the ES-2 works with lenses that do not have internal focusing.
And since the AF 55mm 2.8 goes up to the 1/1 ratio, I won't need a PK-13 ring.
Thank you again, I will buy an ES-2 without fear.
olivierssd
« Reply #5 on: July 21, 2023, 18:46:50 »
Hello Pluton,
Thanks for the confirmation that the ES-2 works well with the 55mm 2.8 which also has no internal focuser. That's 2 practical confirmations, that's great.
Thank you very much for sharing your experience.
olivierssd
« Reply #6 on: July 21, 2023, 19:02:01 »
Hello Eric Lund,
Thank you for the information regarding Silver Fast. I will download the trial version and test the software before buying it.
The ES-2 can be used as a troubleshooting tool when my scanner gives up the ghost!
Thanks a lot
olivierssd
« Reply #7 on: July 26, 2023, 19:21:47 »
Hello,
Finally, I applied this procedure, it's easy and it works perfectly: problem solved.
https://analoghaus.org/using-nikonscan-on-windows-64-bit/
