Author Topic: July 2023  (Read 42843 times)
Re: July 2023
« Reply #120 on: July 16, 2023, 13:19:35 »
Sunset sky
Z7, 24mm f/1.8S
Re: July 2023
« Reply #121 on: July 16, 2023, 14:46:03 »
The annual floating lantern festival to pray for the ancestors that would be held on every July 16th had been cancelled for three or four years due to the COVID 19 was finally held today.
Re: July 2023
« Reply #122 on: July 16, 2023, 15:59:19 »
That must have been an emotional event, Akira....
Re: July 2023
« Reply #123 on: July 16, 2023, 16:26:24 »
A friend returned a loaner camera (Panasonic GF1) and with it came also the little fisheye lens Meike 3.5mm f/2.8 that I had all but forgotten about. So of course Ruth's cucumbers had to be documented again :)
The angle of view is a healthy 200 degrees and getting parts of your body or fingers into the image is a breeze. Guess my top was bright green!!
The lens is actually quite sharp, but the age of the Panasonic sensor shows and the outcome is so-so. Perhaps better light conditions could have improved the final result? Anyway, it was just a functional test.
Ian Watson
Re: July 2023
« Reply #124 on: July 16, 2023, 17:06:28 »
Sunset sky
Spectacular colours, Fons.
Ian Watson
Re: July 2023
« Reply #125 on: July 16, 2023, 17:08:09 »
The aerial truck was a big hit with the children.
Nikon Z6, 24-70mm f/4S.
Re: July 2023
« Reply #126 on: July 16, 2023, 17:31:11 »
Yes, the shimmering lights on the water carry the soothing effect.
Re: July 2023
« Reply #127 on: July 16, 2023, 18:31:05 »
Thank you Ian.
Re: July 2023
« Reply #128 on: July 16, 2023, 18:49:43 »
Masts, Boulogne sur ner.
D750 70-200/4
aerobat
Re: July 2023
« Reply #129 on: July 16, 2023, 22:20:49 »
D850 & AF-S 24mm f/1.8
Daniel Diggelmann
Re: July 2023
« Reply #130 on: July 16, 2023, 23:50:52 »
The summer light in south Spain, full-on color and contrast.
 D3S, 24-70 2.8 vr
Re: July 2023
« Reply #131 on: July 16, 2023, 23:56:21 »
  You did capture a very special ambiance. Thanks for sharing it
Re: July 2023
« Reply #132 on: July 16, 2023, 23:58:28 »
Shameless model  ;D You worked that 24mm to your advantage to tell the story here. It works
Re: July 2023
« Reply #133 on: July 17, 2023, 01:40:40 »
Thank you, Paco.  Glad you enjoyed it.
Re: July 2023
« Reply #134 on: July 17, 2023, 13:00:58 »
July 17
Tomatoes homegrown
D850, 28mm f/1.4
