Author Topic: Nikon D3 compatibility: Zeiss Milvus 50mm f/2.0 Macro Nikon F (ZF.2)  (Read 3192 times)
kasperbergholt
Clever people,
I'm considering buying a Zeiss Milvus 50 2,0 ZF.2 lens. A short while back, I was close to buying a lens that wouldn't work in full-frame mode.
For safety's sake: The 50mm Milvus is fully full-frame compatible, right?
Thanks in advance,
Kasper
-- Kasper Bergholt
Eric Borgström
    • Eric´s pictures
The 50mm f/2 Milvus Makro Planar ZF.2 is a full frame-capable lens, as are the previously issued 50/2 Makro Planars in ZF and ZF.2 flavors. A Nikon PN-11 extension tube will take it to approximately 1:1 reproduction ratio.  I haven't shot much with mine plus the PN-11, but it has been an excellent general purpose 50mm lens from infinity to it's close focus at 1:2. I have the first ZF version for sale locally right now; I switched to the Milvus in order to get the slightly lower amount of flare that the Milvus revision brings.
There is also the Voigtlander 40/2 Ultron SL IIs, the one styled like a 1960s Nikkor. It's not a macro lens but it does focus a lot closer than most normal lenses -  down to 0.25m, giving 1:4 magnification. It has a CPU so is fully compatible with modern cameras. It's a very nice little lens.
And if you don't need the fast aperture and can live without the CPU, the Nikon AIS 55/2.8 or AI 55/3.5 are also optically superb. Both get to 1:2 without accessories.
kasperbergholt
Thank you for the reply - the Voigtlander is a great suggestion. Beautiful work! Regardring the two last ones - the 2.8 will work 'out of the box' as a manual focus lens, right? Whereas the 3.5 needs setting up a profile for it in the shooting menu?
-- Kasper Bergholt
kasperbergholt
https://www.youtube.com/watch?v=H3fRx7Caf90
 :o :o :o
Beautiful lenses! I think the minimum focusing distances of 0.4 and 0.5 meters render them suboptimal compared to the shorter ones for the other lenses (at least for the vacuum tube project).
-- Kasper Bergholt
If you are shooting with your D3, the setup is the same with either 55mm micro.
just enter the CPU data for the lenses: focal length = 55mm, max aperture = f/2.8 or f/3.5 :)
The Voigtlander has a built-in CPU - it is an AI-P lens - so it will automatically transmit the focal length and aperture to the camera, so no need to set up a profile in the shooting menu.
The same can said of the Zeiss ZF.2 lenses, Classic 50/2M  ZF.2 and Milvus 50/2M ZF.2. The older ZF units don't communicate with the camera bodies.
If your budget is on the low side, the Micro-Nikkor 55/2.8 is the best choice IMO.
kasperbergholt
But the Voigtlander lenses (in the YouTube video) are Z mount, right? Will these fit on a D3 without an adaptor?
-- Kasper Bergholt
No. In fact, they cannot be used on the F cameras at all no matter what adapter you try.
BruceSD
  • Confirmed Bokeholic
    • The F/2 Guru
Clever people,
I'm considering buying a Zeiss Milvus 50mm f/2.0 Macro Nikon F (ZF.2) lens. A short while back, I was close to buying a lens that wouldn't work in full-frame mode.
Thanks in advance,
Kasper
Yes, I have one and just went out today and shot a few photos with it on my Z6 camera.  Indeed it does cover a full frame, however, I do notice vignetting in the corners, so I guess that it's full frame coverage is not perfect.
The Zeiss Milvus 50/2 macro is a well made lens.  It's very sharp.  Bokeh is good, but not great.
I own many Zeiss lenses (Milvus and Classics).  The 50/2 Milvus is not one of the better Zeiss lenses (it's not in the 35/1.4,  85/1.4, or 135/2 Milvus leagues).  I also own the Zeiss Milvus 50/1.4.  The 50/2 Milvus is a little sharper, but the 50/1.4 has better bokeh and overall rendering (at least to my eye).
kasperbergholt
Thank you for your reply! I assume it being a macro lens causes disadvantages in comparison to the 35, 85 & 135 lenses? Do you own other macro lenses that are better than the Milvus? The Otus range is stunning.
-- Kasper Bergholt
F2F3F6
Like Bruce said, many Zeiss lenses, known for their sharpness exhibit some vigneting (wide-angle and 50 macro) or CA (100 macro). I had a very good 2/25mm but it had severe vigneting from f:2,0 to f:4 or 5,6.
I tested several other wide-angle lenses from Zeiss and they behave similar...as you can see in some test reports.
For a good macro lens in Nikon F mount, there are some good old Nikkors, like the 3,5/55 or 2,8/55 Micro-Nikkors, the AF-AFD 2,8/60 and AFS 2,8/60.
Or with a longer focal lenght, the Nikkor Ai-Ais 4/105 or the 2,8/105 are also pretty good. Other candidates, the last Tamron 2,8/90 VC macro (better than the Nikkor 105 AFS), or the Sigma 2,8/150 with or without vibration reduction (OS optical stabilization).
Last but not least, the legendary Voigtländer Apo Lanthar 2,5/125, but this one is getting pricey !
