Author Topic: May 2023  (Read 39884 times)
Re: May 2023
« Reply #60 on: May 09, 2023, 10:11:02 »
Colin are you using your phone for photography here in Spain? Muy bien ;)!
Re: May 2023
« Reply #61 on: May 09, 2023, 10:26:56 »
An old water pump.
Re: May 2023
« Reply #62 on: May 09, 2023, 12:25:12 »
May 9
Scilla peruviana, or Portuguese squill, popping through the sword-like leaves of an Iris.
Zfc  Voigtländer 180mm f/4
My issue with the Z fc is the in-camera draining of the batteries, wonder if thats a common problem!
Re: May 2023
« Reply #63 on: May 09, 2023, 13:54:14 »
My Z fc cameras have a lean battery appetite. Not up to the frugality of the Df, but not  bad at all.
Re: May 2023
« Reply #64 on: May 09, 2023, 17:48:21 »
Reading coffee grounds on a table corner. iPhone snap
aerobat
Re: May 2023
« Reply #65 on: May 09, 2023, 21:14:18 »
D850 & AF-S 300mm f/4.0 PF - don't know if the composition works - I was a bit limited by the focal length selection
Daniel Diggelmann
Re: May 2023
« Reply #66 on: May 09, 2023, 21:43:00 »
Rain all day...
Z9  Nikkor 85mm f/1.8 K-version
Re: May 2023
« Reply #67 on: May 09, 2023, 23:01:51 »
Works well in my opinion.
aerobat
Re: May 2023
« Reply #68 on: May 10, 2023, 04:56:54 »
Many thanks Bent
Daniel Diggelmann
Re: May 2023
« Reply #69 on: May 10, 2023, 05:22:14 »
Nice image, Daniel.  Maybe I would shoot a little earlier.  While the moon hasn't risen that high, there would be more compositional freedom.
Re: May 2023
« Reply #70 on: May 10, 2023, 07:39:11 »
Yes, agree, It would decrease the distance moon-earth to have more possibilities for a better composition.
Re: May 2023
« Reply #71 on: May 10, 2023, 09:29:16 »
When my grandson gathers his finds. iPhone grab
Re: May 2023
« Reply #72 on: May 10, 2023, 09:31:41 »
The grandson has a keen eye. Like you :)
Re: May 2023
« Reply #73 on: May 10, 2023, 09:34:54 »
3 years old, he sees things. Thanks, Birna
Adli Wahid
Re: May 2023
« Reply #74 on: May 10, 2023, 13:07:50 »
Short outing with the D700 + Nikkor-H Auto 50mm f/2
