Author Topic: May 2023  (Read 42282 times)
Re: May 2023
« Reply #15 on: May 03, 2023, 01:54:16 »
Smartphone
Dogman
Re: May 2023
« Reply #16 on: May 03, 2023, 14:22:23 »
The house on the corner.  Fuji X-Pro1, 23/1.4 Fujinon lens.
Re: May 2023
« Reply #17 on: May 03, 2023, 17:14:40 »
May 3
Trees in spring
D3S  70-200mm f/2.8
Re: May 2023
« Reply #18 on: May 03, 2023, 22:10:27 »
A bit late for the Magnolia...
D850  AF-D 70-180/4.5-5.6
Ian Watson
Re: May 2023
« Reply #19 on: May 04, 2023, 04:00:02 »
Nice one, Colin!
Ian Watson
Re: May 2023
« Reply #20 on: May 04, 2023, 04:00:59 »
I suspect that John's cat is involved.
Nikon Z6, 24-70mm f/4 S.
Re: May 2023
« Reply #21 on: May 04, 2023, 05:16:38 »
Thanks Ian
It's amazing how some Mediterranean light can inspire the photographic juices
Ha!
Sounds like the secret is out John ;)
Re: May 2023
« Reply #22 on: May 04, 2023, 10:48:53 »
Time to turn into the IR world again .... The ancient Nikkor-N 5cm f/1.1 is a wonderful lens for IR, if one remembers to not stop it down beyond f/8 or so. This is f/11 so a pesky hot spot is starting to show and I had to trim the outcome in order to get rid of the worst side effects.  The sharpness is impressive, even more so when one considers this is a lens nearly 70 years old!.
Nikon Z5 Primaluce-modified, Nikkor-N 5cm f/1.1, R72 filter
Re: May 2023
« Reply #23 on: May 04, 2023, 11:42:56 »
May 4
Green endives
Df  zf 28mm f/2
Re: May 2023
« Reply #24 on: May 04, 2023, 15:49:33 »
My daughter gave birth to a healthy son.  So I am officially Granddad now...
Z6 58G
Re: May 2023
« Reply #25 on: May 04, 2023, 15:58:36 »
Congratulations -- now you will never run out of possible subjects to photograph :)
Re: May 2023
« Reply #26 on: May 04, 2023, 16:01:18 »
Z6 58G
Gefeliciteerd John!
Re: May 2023
« Reply #27 on: May 04, 2023, 16:08:36 »
hahaha,  Thanks Birna and Fons.
Re: May 2023
« Reply #28 on: May 04, 2023, 16:10:29 »
Thanks Ian
Ha!
haha.  Yes it's convenient to have a cat ;)
Thomas Stellwag
Re: May 2023
« Reply #29 on: May 04, 2023, 16:23:48 »
Z6 58G
congrats, grandpa
..but Z658G  is a name, that sounds like an Elon Musk child..
Thomas Stellwag
