Author Topic: The Voigtlander 65mm-APO Z lens Compared  (Read 6136 times)
Re: The Voigtlander 65mm-APO Z lens Compared
« Reply #15 on: December 31, 2022, 09:44:07 »
Interesting...... :-)
The compensating type has the "scalloped" (hill and dale) focus ring.
« Reply #16 on: December 31, 2022, 10:09:40 »
This is what I have.
« Reply #17 on: December 31, 2022, 10:13:20 »
That is the one :-)
Maybe you can check first with a single frame is you are satisfied with 3.5 or 5.6 is better.
Probably at high magnification 3.5 will give higher resolution.
« Reply #18 on: December 31, 2022, 10:20:29 »
It it easy to check if it "compensates" if set to e.g. f/8 and lens is at infinity the aperture will open up when lens is focused closer.
At 3.5 it will just stay at 3.5.
« Reply #19 on: December 31, 2022, 10:27:15 »
Please explain more just how "compensating" works in a lens.
« Reply #20 on: December 31, 2022, 10:47:18 »
As far as I know this is the only F-mount Nikkor that compensates the aperture when focused closer.
It will compensate for the loss of light which occurs when magnification gets higher (focused closer).
It the old days where you did manuel measurement of the light you only need to do it once at one magnification and the lens will make the adjustment when focused (but not at 3.5).
Nikon may explain it a bit different but that is the idea. If camera has light measurement through the lens like modern camera bodies it is not at problem.
Richard also like the lens (the compensating mechanism is showed):
https://richardhaw.com/2017/01/18/repair-micro-nikkor-p-55mm-f3-5-auto/
« Reply #21 on: December 31, 2022, 11:19:25 »
An easier way to explain the light loss with higher magnification is that the length of barrel increases when focused closer so light has to travel longer.
« Reply #22 on: December 31, 2022, 11:22:16 »
Here are three photos.
(1) 55mm f/3.5 COMP stacked on center and finished as the others.
(2) 55mm f/3.5 COMP untouched single shot
(3) 55mm f/5.6 COMP untouched single shot
« Reply #23 on: December 31, 2022, 12:08:25 »
Thank you very much for this comparation.
It confirms that it is a fine lens?
There is a difference in background blur. Not that the 55/3.5 looks bad but with 65/2 it is more "blurred" like "vaseline".
Also it looks like with 55/3.5 the front red leaf of the flower has a bit more DOF so more of it is in focus?
« Reply #24 on: December 31, 2022, 12:31:58 »
The resolving power of the 55/3.5 may be a bit higher at 5.6 if I look close to the monitor with +2 glasses.
It seems the 65/2 does this already at f/2.
Still I am impressed by the old 55/3.5 with only 5 lens elements.
Stevelink3
  • You ARE NikonGear'23
    • Total Quality Photo
Re: The Voigtlander 65mm-APO Z lens Compared - A question please
« Reply #25 on: December 28, 2025, 04:43:27 »
Hi Michael.
As a landscape, wildlife and product photographer with an obsession with image sharpness and detil ssince I often print large, I currently shoot my macro and product work with the IRIX 150 f/2.8 Macro lens (Z mount). While it is quite sharp, I've lately heard positive things about the stellar sharpness of the Voigtlander 65 f/2.8 APO-LANTAR Macro lens for Nikon Z mount. So, I see you rate the Voigtlander as being sharper than the Nikkor MC 105 Z lens. Do you also think that it is sharper than the IRIX 150 f/2.8 Macro? Thank you very much! Happy Holidays,
Steve
P.S. - For reference, I attached a Focus Stack Macro using that Z8 and IRIX 150 f/2.8 Macro.
« Reply #26 on: December 28, 2025, 09:40:04 »
I don't have the IRIX 150 f/2.8 Macro. Sorry. I am doing most of my work at this point on the Hasselblad X2D Mark II, which is a very different beast.
