Author Topic: Firmware update D850 firmware version 1.21  (Read 3686 times)
« on: October 28, 2022, 21:36:51 »
A firmware update for the D850, sounds like a minor update, but who knows..
https://downloadcenter.nikonimglib.com/en/download/fw/469.html
Re: Firmware update D850 firmware version 1.21
« Reply #1 on: October 28, 2022, 22:09:33 »
Thank you! Yes sound minor but I'll try it out anyway
« Reply #2 on: October 31, 2022, 10:49:00 »
Looking forward to seeing your results, since my D850 works fine now and i have had 3rd party lenses disabled in the past by "minor" firmware updates. Don't want that anymore  ;D
« Reply #3 on: October 31, 2022, 10:51:03 »
Disabled what do you mean, Hans
« Reply #4 on: October 31, 2022, 15:45:09 »
Tamron lens(es) not autofocusing anymore  >:(
« Reply #5 on: October 31, 2022, 16:49:04 »
I have but one Tamron lens the 45mm f/1.8 and it focuses fine on my D850 after the update.
Hans, did you try a different body to check the tammy for autofocus, maybe check with Tamron for advice if the problem persists.
« Reply #6 on: November 01, 2022, 15:27:51 »
Thanks Fons.
I haven't yet updated to this version, so not having problems now. At the time (had it once with the D810 and D850), i did check the lens for AF on another body and it worked fine. So, as long as my body is working fine for me with my set of lenses, i'm not updating  ;)
« Reply #7 on: February 28, 2023, 20:12:01 »
Now also firmware 1.30 for the Nikon D850
   https://downloadcenter.nikonimglib.com/en/download/fw/484.html
 Added [Portrait impression balance] to the photo and movie shooting menus. For more information, see Supplementary Firmware Update Manual. To view NEF (RAW) pictures taken using firmware version 1.30 or later on a computer, you will need to update NX Studio to version 1.3.1 or later and Picture Control Utility 2 to version 2.4.14 or later.
• Fixed an issue that resulted in attempts to initiate [Lock mirror up for cleaning] in the [SETUP MENU] causing the camera to display the message “Disable [Network connection] in the Bluetooth menu” and lock the mirror in the down position, preventing it being raised for cleaning, when [Enable] was selected for either of the following [SETUP MENU] items:
    - [Bluetooth] > [Network connection]
    - [Airplane mode]
