Author Topic: Nikon Df vs Newer Nikon Mirrorless Bodies  (Read 5536 times)
BruceSD
  • Confirmed Bokeholic
    • The F/2 Guru
« on: July 02, 2022, 06:55:52 »
A few years ago I owned a Df body.  I had it only a short period of time before selling it.
Lately I've been mostly shooting my Z6 body.
While the images I'm making with the Z6 are very nice, I kind of wish that I'd kept my Df so I could directly compare the image quality between the two bodies.
Do any of you own both the Df and one of the modern full frame mirrorless offerings from Nikon?  How doe the image quality of color files compare?   How do the black and white files compare?
From my very limited personal experience and research, I think I might slightly prefer the IQ of the Df over the Z6.  Which do you prefer and why?
Re: Nikon Df vs Newer Nikon Mirrorless Bodies
« Reply #1 on: July 02, 2022, 09:13:26 »
A good and relevant question, Bruce.
The answer probably depends on the manner in which you shoot and how you process your captures later. I regard the Zx cameras as picture machines and the Df as an imaging tool.
Kenneth Rich
« Reply #2 on: July 02, 2022, 16:33:45 »
Picture machine. . . . . . imaging tool. I like that, Birna, thank you. The little Darling and the Da Vinci, in my case.
« Reply #3 on: July 02, 2022, 19:38:11 »
I’ve used Df, Z6 and Z9. They are all good. It took me longer to get good images with the Z6, but once I figured it out I did not really pick up the df again.
BruceSD
    • The F/2 Guru
« Reply #4 on: July 03, 2022, 02:54:08 »
Thanks to all for taking the time to respond!
I'm not yet fully comfortable with my Z6.  Maybe in time, I'll be like Jack and fine tune it's capture setting and post processing protocol and realize images that I love.  I guess that it just takes time.
Bern
« Reply #5 on: July 03, 2022, 16:25:18 »
Do you still get to use your DF since moving to the Z system? Or has the Zfc totally replaced the Df?
The Nikon Df was once a dream camera for me, however, I couldnt  justify the price. Now am really thinking hard if I can shift to the  system. Am slowly selling some of my seldom used Nikkor F lens to help fund the switch.
Keep shooting,
Bern
« Reply #6 on: July 04, 2022, 10:52:43 »
... I think I might slightly prefer the IQ of the Df over the Z6.  Which do you prefer and why?
From what was told by Nikon Pro Service when Df was released;
The Df sensor is based on the sensor of the D4, and the difference/advantage of the Df is that the sensor and electronics are fully designed without video to provide a very clean image.
I'm sure you can find more if you go back and look when it was released.
Much more on the Df;
https://nikongear.net/revival/index.php?topic=9850.0
dko22
« Reply #7 on: August 12, 2022, 17:33:11 »
I own both the Df and Z6. There are sometimes marked differenced in the colour rendering between the two cameras but it would be hard to say which one is better. Partly because aperture information is retained and partly because it's simply a more natural experience, I now use my MF legacy primes and AF-D lenses such as the excellent 80-200 mainly with the Df rather than through the adaptor and the results are at least on a par. At very high ISO, the Df has extremely good colour retention at the expense of slightly more noise than the Z6 (at any rate when equalized for resolution) but they're both fine in 99% of situations.
RobOK
    • My gallery
« Reply #8 on: September 07, 2022, 18:21:19 »
Can't Nikon please put the Df sensor in a Z body and call it a day? Charge $2000 and half the people on this forum would buy it!
« Reply #9 on: September 08, 2022, 15:01:20 »
I'd rather have a Df-like body, i.e. a full frame Zf
RobOK
    • My gallery
« Reply #10 on: September 08, 2022, 16:27:35 »
Can you expound on this? The Z being a "picture machine" implies being a bit cold and clinical, or am i reading into your comment too much? I have Z6 and a Df, but the Df has not gotten much use lately (and I gave the D750 to my nephew to "pay it forward" I hope!)
Kenneth Rich
« Reply #11 on: September 09, 2022, 17:59:11 »
Call it a day, certainly, but get off to an earlier start, with an OVF, mirror and prism and a full 35mm frame- an earlier sunrise, not stretch the sunset, Nikon, just start the day where it should have started- on  a new FM sized Df- years ago.
mxbianco
« Reply #12 on: September 10, 2022, 19:28:04 »
I have both: Df and Z6, and I use both, my Df has about 182000 actuations, my Z6 only 5000... (vs 40k for my Z7)
This summer I have used my Df in the mountains with my 28-300 lens, a jolly lens that's good enough for a 16 Mpix sensor
I use the Z6 for night street photography, the electronic viewfinder helps a lot in dark corners, with a traditional optical finder you wouldn't even be able to frame the pic...
Ciao from Massimo
Michael Hopferwieser
« Reply #13 on: September 19, 2022, 13:56:52 »
Ciao from Massimo
Hello Massimo, I am using Df and prime lenses as 35mm 1.4, 50mm 1.2 and 105mm 2.8. You mentioned, that your 28-300 is good enough for a 16 mpix sensor. Would You be so kind to explain this. Thanks a lot Michael
RobOK
    • My gallery
« Reply #14 on: September 19, 2022, 17:42:31 »
Sometimes the faults of lenses are apparent on high resolution sensors. He is saying that since the Df sensor is relatively speaking lower resolution, that this lens can stand up.
Of course todays lenses and sensors are usually far outpacing us photographers capabilities!!
