Author Topic: July 2022  (Read 38051 times)
Re: July 2022
« Reply #120 on: July 18, 2022, 21:29:10 »
July 18
Hot day stay in the shade
Zfc - 16-50mm f/3.5-6.3
Re: July 2022
« Reply #121 on: July 19, 2022, 00:01:45 »
July 16
Installation
Den Hoorn, Texel
Z6, 20mm f/1.8s
July 18
July 14
Falling from the sky
Z6, 70-300mm f/4.5-5.6E
Fons, I very much like the composition in all this three images. Lovely rhythm and reading of the frame.
 I may take a look at cropping some sky on the right-hand side of the flying people as it may make it more surreal...
Re: July 2022
« Reply #122 on: July 19, 2022, 00:04:21 »
Thank you all for the nice comments.
  Today, a few leading lines in the subway. I'm still way behind sorting out the images because I'm on vacation and shamelessly lying on the beach   8)
  Z6, 24-70mm f4.
Re: July 2022
« Reply #123 on: July 19, 2022, 06:38:06 »
Thank you so much Paco! Great stairway shot.
Re: July 2022
« Reply #124 on: July 19, 2022, 11:06:49 »
Sister Shot. Brighton.
Re: July 2022
« Reply #125 on: July 19, 2022, 15:24:41 »
Dusk scene.
Re: July 2022
« Reply #126 on: July 19, 2022, 19:38:56 »
Close to 40 degrees Celcius today,
A cold beer on a terrace
Z6  105MC
Re: July 2022
« Reply #127 on: July 19, 2022, 20:55:34 »
Nice choice John, it make me thirsty  ;D
  Akira, lovely spot. This time, even more dramatic lighting. The reds in the sky like coming straight from "stranger things"
Re: July 2022
« Reply #128 on: July 19, 2022, 20:58:58 »
Part of a rehearsal in Barcelona.
 Z6 with the 24-70mm f4. I was not prepared, gear wise, for this shot. I had to crank up the iso and gert closer. The results were different than usual. Limitation is inspiration  ;)
Re: July 2022
« Reply #129 on: July 19, 2022, 21:31:02 »
Thanks Paco
Despite the 'limitation' an intriguing image. ;)   like the contrast between movement and non-movement
Re: July 2022
« Reply #130 on: July 19, 2022, 22:26:03 »
July 19
Hot day on the beach
Zfc, 70-300mm f/4.5-5.6E
Re: July 2022
« Reply #131 on: July 20, 2022, 01:06:33 »
Thank you, Paco.  I shot the same sky with my Sigma fp with the 45mm lens, but preferred this one shot with my iPhone SE2 with a 26mm-equivalent lens because of the very reason you pointed out.
Re: July 2022
« Reply #132 on: July 20, 2022, 15:59:32 »
The annual fair has arrived in Tilburg and will start Friday evening.  After two years nearly non existent because of Covid now finally without any restrictions
Waiting to be installed....
Z9 58G
Re: July 2022
« Reply #133 on: July 20, 2022, 19:55:46 »
July 20
Seaside
Z6, 85mm f/1.8s
Re: July 2022
« Reply #134 on: July 20, 2022, 23:43:13 »
Thanks PacoDespite the 'limitation' an intriguing image. ;)   like the contrast between movement and non-movement
  Thanks John, so do I!
