Author Topic: [Theme] Trees  (Read 108177 times)
[Theme] Trees
« on: June 08, 2022, 08:07:09 »
From my last excursion in the forest, the estate of Joppe. A beech lined forest track.
Z6, 85mm f/1.8s three image stack
Re: Trees
« Reply #1 on: June 08, 2022, 12:35:38 »
Nice ;)
Lars Hansen
  • Zealand, Denmark
Re: Trees
« Reply #2 on: June 08, 2022, 18:18:24 »
Nice it is  :)
Do we have a theme with trees at NG? .. if not, I think we ought to.
Re: [Theme] Trees
« Reply #3 on: June 08, 2022, 19:04:13 »
Nice it is  :)
Nice ;)
Thanks
Robert Camfield
  • Hello from MadTown
Re: [Theme] Trees
« Reply #4 on: June 08, 2022, 21:38:38 »
Fons,
Yes, an engaging photograph...makes you wish you were there on a walk through the forest.  Just curious: any adjustments to the image? Frankly, it looks quite normal, as in Nikon's so-called "Standard" without adjustments to normal setting.
Thanks, Robert
Re: [Theme] Trees
« Reply #5 on: June 08, 2022, 22:04:12 »
Fons,
Thanks, Robert
Thank you,
I may have used portrait mode in photoshop
this is one of the three images of the photostack merge
i generally use flat or portrait depending, and adjust the exposure when needed
Z6, 85mm f/1.8S @ f/8 iso 7200-8000 and reduced the quality to 80% because of max filesize on the forum
Re: [Theme] Trees
« Reply #6 on: June 09, 2022, 03:09:41 »
Fons, I think you hit a blind area.  This thread is absolutely worth participating!
Re: [Theme] Trees
« Reply #7 on: June 09, 2022, 08:05:57 »
Thank you Akira, let's contribute!
Re: [Theme] Trees
« Reply #8 on: June 09, 2022, 10:43:00 »
Great idea Fons and Akira. I have some [pictures of] trees  ;D
First one, from times past ... pre-covid, pre-Z, etc.
Re: [Theme] Trees
« Reply #9 on: June 09, 2022, 11:44:40 »
Great images Fons and Hans.
Heres one from the 1980's
Ilford FP4 taken on a simple Olympus Trip
The original print was selenium toned and had a wonderful depth to it
Lars Hansen
  • Zealand, Denmark
Re: [Theme] Trees
« Reply #10 on: June 09, 2022, 12:26:09 »
Great Fons - now I know where to put my tree images and look forward to tree images from other members :)
A local tree I like to walk by now and then - evening a few days ago.
Re: [Theme] Trees
« Reply #11 on: June 09, 2022, 12:43:23 »
Thank you
"..Its about trees, you see..
Trees are majestic, mysterious, magical...
and an absolute necessity for the health of the planet
and her inhabitants.
So plant trees and show us your artistry..."
Lars Hansen
  • Zealand, Denmark
Re: [Theme] Trees
« Reply #12 on: June 09, 2022, 12:53:21 »
Well put Fons.
A group of oaks (I believe) I found behind a meadow - late April. Added an "acrobatic" tree  :) (from the same spot)
Re: [Theme] Trees
« Reply #13 on: June 09, 2022, 13:02:42 »
From October 2014
Df, 58mm f/1.4
Re: [Theme] Trees
« Reply #14 on: June 09, 2022, 18:26:38 »
From October 2011
D700, 14-24mm f/2.8
