Author Topic: Nikon NIKKOR Z 100-400mm f/4.5-5.6 VR S Lens  (Read 10008 times)
Re: Nikon NIKKOR Z 100-400mm f/4.5-5.6 VR S Lens
« Reply #15 on: March 17, 2023, 12:10:42 »
I just went through Rebecca Danese's comparison of the 70-200/2.8 and 100-400 Z lenses in the latest issue of the Nikon Owner magazine. I couldn't really tell from the small comparison images presented at 400mm (with the shorter zoom using the 2X TC to get to 400mm) but the author said the 100-400 is sharper at 400mm than the 70-200+2X which is as one would expect and she said she prefers the 1.4X. I'm wondering if the Z 70-200/2.8 combined with Z TC 1.4X would work for my intended frog application or if I would be better off with the 100-400. I have a 200mm Micro-Nikkor which I have used previously in this context, but somehow the out of focus areas sometimes have elements that sometimes rub me the wrong way (being used to newer lenses where there has perhaps been more emphasis on bokeh). I also have a 105 MC which is fabulous but it's uncertain if it is long enough in this context (some of the time it may be but my recollection is that the 200mm gave a distinct advantage).
From the images I have seen of the 100-400mm, I think the 400/4.5 has the edge in bokeh at longer distances (such as when photographing deer), but doesn't focus as close as the zoom does (0.16x vs. 0.36x maximum magnification for the 400/4.5 and 100-400, respectively).
« Reply #16 on: March 17, 2023, 12:17:44 »
[quote author my intended frog application 0.36x maximum magnification for the 400/4.5 and 100-400, respectively).
[/quote]
What type of frogs are you looking to photograph? Where I live here in northern Michigan, the first to sing are the chorus frogs and wood frogs, followed by the spring peepers, and then gradually the green frogs and others come in, and then the trilling of the toads.
« Reply #17 on: March 17, 2023, 12:36:41 »
These
https://www.flickr.com/photos/ilkka_nissila/51139092599/in/album-72157608284582293/
I believe they're European toads.
« Reply #18 on: March 17, 2023, 12:41:57 »
These
No, those are frogs, but without clear color I can't see which ones. They look like Rana Clamatans (Green Frog), yet I can't see them well enough.
« Reply #19 on: March 17, 2023, 16:15:45 »
Maybe rana temporaria?
I am new to frogs. :) I can ask locals at the next opportunity.
« Reply #20 on: March 17, 2023, 16:22:43 »
I don't European names. If you have a photo of the frog where I can see the whole body, I would know.
« Reply #21 on: March 19, 2023, 14:21:19 »
I wonder if the 100-400 performes better at 400mm (at 5.6) than the 400/4.5 SR lens?
The 100-400 has more exotic glass and is not "compromised" by the SR lens element?
Price is about equal. 100-400 a bit cheaper.
« Reply #22 on: March 19, 2023, 15:58:34 »
I can see that the SR lens element is not a Fresnel but another exotic glass element.
The 400/4.5 is so short so I thought it was compromised by a Fresnel element.....but it is not.
Wally
  • X-Man breaking bad
« Reply #23 on: March 19, 2023, 20:26:53 »
from Tom Hogan:
Quote>
Compared to the 100-400mm f/4.5-5.6 VR S at 400mm f/5.6, the 400mm f/4.5 VR S is somewhat better wide open, pretty much across the board, and clearly better at the same f/5.6 aperture.
Finally, the 400mm f/4.5 VR S is a little better with a 1.4x teleconverter than the 100-400mm f/4.5-5.6 VR S, but both are quite good. In the F-mount world I was not a fan (or user) of teleconverters. In the Z-mount world, I'm coming around to liking (and using) them, at least the 1.4x version.
Unquote>
Note that the zoom is 60g heavier but has a much better close focus.
« Reply #24 on: March 19, 2023, 22:37:30 »
Ok, yes it can also be seen at the MTF curves that the 400/4.5 is a bit better.
I think the 400/4.5 is more for me than the 100-400 but a big shame about the close focus.
There is also the question if you should get a 500/5.6 PF instead if you can find a good 2. hand offer.
MILLIREHM
  • Vienna, Austria
« Reply #25 on: March 19, 2023, 23:14:43 »
its one of the three euorpean brown frog species, Rana temporaria or Rana arvalis (the third Rana dalmatina ist not present in Finland)
Wolfgang Rehm
MILLIREHM
  • Vienna, Austria
« Reply #26 on: March 19, 2023, 23:20:14 »
The SR lens elements are a new feature of Nikon to better correct chromatic aberration for blue light IIRC.
and no the 400/4,5 hast no Phase -Fresnel Element (despite expectations due to symmetry 400 and 600 TC with FL, and 800/6,3 and 400/4,5 with PF).
I would not mind if it contained a PF element and was even more compact. (I dont consider the 800/6,3 to be "compromised" by its PF design btw)
Have made good experiences with the 80-400 AF-S F-mount for pthotographing frogs so will probably go forthe 100-400 (havent got one yet), the 400/4,5 does not tempt me.
Wolfgang Rehm
« Reply #27 on: March 19, 2023, 23:31:26 »
Rana temporaria (actually all three you mentioned we call the Wood Frog (very early) Rana Sylvatica, with a mask. They appear here is small, dark, spring ponds and streams....quite early, making a croaking sound. Thanks.
Here is a shot I took of our "Wood Frog." Just screen dumped from a book I wrote.
Wally
« Reply #28 on: March 19, 2023, 23:39:57 »
another quote from Tom Hogan:
Compared to the F-mount 500mm f/5.6E PF, the 400mm f/4.5 VR S with a 1.4x teleconverter (560mm, so not perfectly comparable) seems to do slightly worse in the center, slightly better in the corners. For most telephoto work, sharper centers is what you want, so don't throw that 500mm PF away just yet ;~).
Personally I would/will go with the Z lens. Why? lower weight 200+ grams (w TC-1.4 vs. FTZ), better VR, modern optics
« Reply #29 on: November 17, 2023, 19:35:01 »
I finally got the 100-400 a couple of weeks ago.
I very much like the mechanical construction, the zoom requires some force to apply but not as much as the 200-500, so the 100-400 is faster to use but still more work than, e.g., 70-200 to zoom from end to end.
The tripod mount feels sturdy and rotates smoothly. I can mount a plate with two screws and there is no risk of slipping or unintended rotation.
The zooming, as Nikon advertised, doesn't cause much of a center of gravity shift so on my small Gitzo fluid head, no rebalancing is needed after zooming. This is great and one of the reasons I felt I could get this lens.
It doesn't have the kind of "almost sharp" appearance of the 80-400 at slow speeds (well, at the time I didn't have access to electronic shutter, so that can play a role), and even the maximum aperture can be used safely.
Bokeh is ok but it's not as nice as a non-PF prime. There is some swirl in the outer areas of the frame. I think it's "intermediate" in the quality of out-of-focus rendering overall.
So far my main source of disappointment is focus at near distances. The lens focuses really close, but autofocus for near subjects with the Z8 has been ... well, poor. Manual focus is frequently needed. I have shot with the lens in bright daylight (though this is relative, we are talking about November in Finland here ;-)) as well as in the pine forest floor in low light, and a lot of the time my ISO is above 12800, alas. However, this situation will improve it's just the worst time of the year for light levels before the snow falls and changes the landscape.
I post one example that I took yesterday. Z8, 100-400mm at 400mm f/5.6, 1/500s, ISO 11400. A slight crop has been made, maybe 1.2x. I think it's funny to think that it's the sun which creates those variations in light and this is around 2 pm in the afternoon, but still, ISO 11400!!! Welcome to Finland ... The picture was processed in NX Studio with noise reduction set to Normal. I think Nikon should rethink their high ISO noise reduction algorithm for the highest ISOs it's not the best. But at this size it's not too bad. My license for DXO unfortunately doesn't cover the Z8 so I have to think about upgrading.
Anyway, I'm wondering if there are any tips for how to deal with the autofocus when photographing small birds. I have tried 9-point dynamic area and small, large and custom wide area with animal detection and it isn't too reliable for blackbirds in these conditions. The found subject bounces around a lot. If it loses focus it can lose it so badly it stops trying. Is this the bright new mirrorless future?
