Author Topic: Interesting options for macro work  (Read 4226 times)
« on: March 16, 2022, 20:41:50 »
I'm always impressed by some of the exotic lenses I see you guys adapting for everyday use.
I saw a rather nice macro taken with the lens from a Minolta Dimage Scanner.
I've got one of these that has already scanned all the negs I own and I suspect a few other people have one too.
Maybe it's time to cannibalise mine too!
More details here
https://www.closeuphotography.com/minolta-dimage-scan-elite-5400-lens-removal/
Of course, some of you may have already tried this - if so, please let us know how you got on, plus any alternatives you'd recommend
Re: Options for macros work
« Reply #1 on: March 16, 2022, 20:43:43 »
Heres a result taken by Javier Ruperez
I found this in the "Extreme Macro" group on Facebook
« Reply #2 on: March 16, 2022, 22:05:02 »
I have the lens and also the Nikkor for the ED 5000 and 9000 scanner.
The Dimage 5400 lens is quite nice. I have only used it for some "playing"......nothing serious.
The tube I painted inside with anti-reflex paint and the rubber O-ring is quite important to avoid false light as it will reduce contrast a bit. There are many other ways to avoid it......but this was my solution.
I have also a tube for the ED 5000 Scanner Nikkor and all the parts to mount the ED 9000 Scanner Nikkor but have not had the time yet to finish the project. Flocking material for the tubes etc. I have also.
« Reply #3 on: March 16, 2022, 22:40:32 »
A small example more. I just did a snapshot with the lens. A small vintage wrist watch and a 100% crop.
I think the A in INCABLOC is close to be in 100% focus. DOF is very limited.
« Reply #4 on: March 16, 2022, 22:50:09 »
What I like is that I don't see any "out-of-focus" CA.
Don't think I have many lenses that are better corrected than this one.
Re: Interesting options for macro work
« Reply #5 on: March 17, 2022, 01:12:16 »
Lovely to see the construction work you did Meper and the results of this.
I guess the lens is working in the conditions for which it was designed.
I've never attempted such a setup and appreciate as much investment of effort is needed for the macro stages, plus stacking to get results like the beetle posted earlier.
I'd be interested to know what drew you towards this approach and whether this Minolta lens was especially singled out in what you read about, or if most scanner lenses would perform similarly?
I guess these slide/negative scanners probably sell cheaply nowadays so are a good source and may have been mentioned in other online articles
Now that I've looked through a bit more at https://www.closeuphotography.com I can see I've a lot to learn
« Reply #6 on: March 17, 2022, 08:03:02 »
It was from "closeuphotography" I learned about the lens.
Seems the Dimage 5400 lens, ED 5000 and ED8000/ED9000 scanner lenses are on top.
I searched Ebay for these lenses and I the Minolta 5400 lens, 2 x Nikkor ED5000 lenses and one ED9000 Nikkor lens.
Seems these three lenses are the top of the top when compared with other scanner lenses or "general purpose" lenses like the Canon MP 65 lens which he use as a reference.
I have all the parts to be able to make this setup for the ED9000 scanner lens:
https://www.closeuphotography.com/scanner-nikkor-ed-lens/2017/6/21/scanner-nikkor-ed-lens
The lenses where quite cheap compared to the optical quality you get. I think prices may have raised a bit. The ED8000/ED9000 lens is a 14 element lens with a lot of ED-glass. Seems close in design to the printing Nikkor but scanner Nikkor much cheaper. I have an ED9000 scanner but don't want to pull the lens out as I use the scanner from time to time.
Now most know that ED8000/ED9000 scanners has a very nice lens but before then I think a non-working ED8000/9000 could be purchased cheap.
If you see one on Ebay as a reasonable price be sure that none has been inside the scanner to ensure the lens is still there :-)
« Reply #7 on: March 17, 2022, 08:13:47 »
There is a link here for some technical info about the Scanner Nikkors:
http://www.marcocavina.com/articoli_fotografici/articolo%20Scanner%20Nikkor%20ED.pdf
Not as much ED-glass than I initial thought and the small scanner Nikkor is from ED4000 scanner (not 5000 as I wrote). Probably confused with Minolta models.
But still very good optical corrected lenses. A shame my Italian is quite bad........
mxbianco
« Reply #8 on: March 17, 2022, 10:49:42 »
Fortunately that PDF is with editable text, so you just copy/paste the part you want translated to Google Translate, and voilà you have your text in any language.
An example with the first paragraph of page 1 translated into English:
SCANNER-NIKKOR ED: THE NEW GENERATION OF OPTICS FOR 3rd MILLENNIUM NIKON SCANNERS
At the dawn of the new millennium, Nikon Corporation renewed the high-end of its film scanners by introducing two versions with very interesting features such as the Coolscan 4000 ED and Coolscan 8000 ED, intended respectively for scanning 24x36mm frames on 135 film and frames. up to 6x9cm on 120 roll, and both accredited with a real resolution of 4000 Dpi with A / D conversion at 14 bit / RGB channel and 16 bit / channel RGB output, really excellent credentials for the time; these data are well known to all enthusiasts and professionals, among whom the fame of the excellent scans allowed by these products spread rapidly; what few people know is that behind this new generation of scanners there was a considerable effort related to the development of a new generation of high resolution intermediate lenses that were able to easily copy the new, very high resolution of the scanners they were intended for, also guaranteeing an excellent correction of chromatic aberration in a wide range of the spectrum between the g-line and the s-line, i.e. between 438.5nm (threshold of the visible towards ultraviolet) and 852.1nm, abundantly in the infrared; this requirement was stringent in Nikon Coolscan because the acquisition used a triple matrix of RGB LEDs (red, green and blue) as a light source, for each of which the optics had to ensure identical sharpness and focus plane.
(Please note that Translate has a limit of 5000 characters per translation)
Ciao from Massimo
« Reply #9 on: March 17, 2022, 11:47:07 »
Yes, thank you for this.....I had it in my mind to try Google translate.....
The technical stuff....with all the curves which shows how well the lenses are corrected for various "defects".....it could be interesting to have comments from some of the few people which actual understands these curves and numbers 100% to comment on how well corrected these lenses are. If no "defects" all curves would just be straight centered lines.....so how nice are these curves?
« Reply #10 on: March 18, 2022, 20:35:49 »
A couple of more snapshots with Minolta Dimage 5400 lens.
One of a small part of an approx. 20 cm paint brush and another of the tip of a ball pen + a 100% crop.
Bokeh looks quite nice but at these rather large magnifications bokeh usually looks nice?
Again CA is well controlled. Often metallic reflections shows CA.
With the small DOF the sharpness has to be right so image looks like a sharp one even that most of image is out of focus. That is an interesting challenge (I have never done stacked images.....yet).
« Reply #11 on: March 18, 2022, 21:07:12 »
What is the magnification here?  These scanner lenses should not be pushed much above 1.5X. I set mine to the recommeded 1.33X.
Focus stacking is a mandatory approach if you want anything else than slices of sharpness and blur otherwise. Or restrict shooting to captures of flat subjects.
« Reply #12 on: March 18, 2022, 21:58:39 »
The paint brush image is the whole frame (non-cropped) about 2 cm at the long edge.
It is a DX-sensor which is 24mm at the long edge so I guess the magnification is close to x1 or a little more than x1.
« Reply #13 on: March 18, 2022, 22:11:33 »
You should fine-tune the setup to give an optinal magnification. It is worth noting that the scanner lenses are most suitable for DX/APS-C format.
The final point is whether one should reverse-mount the lens, or not. The dot marks the subject side, if memory is reliable. Anyway, it is easy to try both orientations and check what delivers the better result.
« Reply #14 on: March 19, 2022, 09:11:01 »
The attached image of the ruler shows that it covers 18mm and DX-sensor is 24mm. Then magnification with current setup is 24/18 = x1.3 ?
The lens is secured with a set screw and lens can slide about 15mm in to shorten the distance with 15mm. This may be enough to tune the magnification to about x1.
To check if lens is better reversed I would need to setup the camera on my focus rail and then I need a test target that can show the difference in resolution. I may have a Kodak test target somewhere.......
