Author Topic: January 2022  (Read 51289 times)
Luc
    • Flickr
Re: January 2022
« Reply #75 on: January 09, 2022, 09:49:23 »
At the entrance of Stadsbos013 on the road to 'Grotto'
The day started sunny and cold, and ended in rain and cold.
Nikon Z6  AIS 80-200/4
Nice scene, John. Same weather in Amersfoort. I was back just in time from my bicycle ride.
Re: January 2022
« Reply #76 on: January 09, 2022, 09:54:57 »
Is this an uncroped APS-C frame?  The Heligon seems to perform marvelously on the relatively large sensor and at distance.
Yes. The field is very flat and apart from some mild blue fringing on high-contrast transitions, the rendition is very smooth with high sharpness.
The 100 Rodenstock will almost cover the 24x36 FX format at infinity focus, but the corners disclose the format exceeds the circle of acceptable image quality. On the Z fc, there is no such issue. The focusing helicoid I put on the 100 Rodenstock allows focus from approx. 80 cm to infinity with the Z cameras, but of course I can add extension if closer focus is desired.
Re: January 2022
« Reply #77 on: January 09, 2022, 10:36:26 »
Beautiful Birna.
Reminds me that I still have to finish the  mount on my Rodenstock....
Re: January 2022
« Reply #78 on: January 09, 2022, 11:20:19 »
Birna, thank you for the details and inspiration.
Re: January 2022
« Reply #79 on: January 09, 2022, 18:08:11 »
Yesterday we had a bit of sun :)
Df 50 50m f1.4 AF @f8
Re: January 2022
« Reply #80 on: January 09, 2022, 21:21:50 »
Forgot to pack my XQD card, so I had to use the iPhone 11.   Like Akira I had my limitations too ;)
On the Regte Heide
Post-processing via Lightroom and DNG files.
Re: January 2022
« Reply #81 on: January 09, 2022, 21:50:48 »
This should be the last one of Ani for a while as I´m back at Cádiz. Beautiful couple of days, sunny and cold.
  She likes the pink flower
   D5, 70-200mm 2.8 fl
Re: January 2022
« Reply #82 on: January 09, 2022, 21:54:13 »
Thanks Luc.  Today was better,  more sun, but occasional rain, in some darker clouds.
Re: January 2022
« Reply #83 on: January 10, 2022, 00:57:49 »
Today I got out with the IR d200 and the 70-200mm 3.5-5.6 vr. That couple works very well indeed.
   The Cathedral of Cádiz
Luc
    • Flickr
Re: January 2022
« Reply #84 on: January 10, 2022, 07:47:31 »
Impressive shot, Paco. Cádiz is, also thanks to your images, definitily on my list of Spanish cities to visit.
Re: January 2022
« Reply #85 on: January 10, 2022, 12:23:30 »
January 10
Morning
D3s, 58mm f/1.4
Re: January 2022
« Reply #86 on: January 10, 2022, 14:18:33 »
January 10
Morning
D3s, 58mm f/1.4
Nice :)
Re: January 2022
« Reply #87 on: January 10, 2022, 14:27:29 »
Thank you Luc. Cádiz will most certainly not disappoint.
  Lovely Fons. The frame partitions in color and sutil leading lines makes perfect set up to read the calm atmospheric ambiance.
Re: January 2022
« Reply #88 on: January 10, 2022, 17:57:55 »
Thank you Bent, than you Paco.
Re: January 2022
« Reply #89 on: January 10, 2022, 21:38:31 »
During the day the fog came
In the background the renovated city hall
Z6  AIS 80-200/4
