Author Topic: What is this? Coma? Comatic aberration?  (Read 2371 times)
frederikboving
    • frederikboving
« on: October 04, 2021, 14:37:08 »
Comes with the Nikon 50mm AF 1.4D + the same in 1.8G.
I tried to stress the lens to produce some coma, and the attached is what I got.
Some long "arms" stretching north and south from the center of the light spot.
This is the extreme corner of the frame you see in the image. Snipe from LR.
Re: What is this? Coma? Comatic aberration?
« Reply #1 on: October 04, 2021, 14:54:39 »
This is an illustrative example to explain how coma looks like.  :)
frederikboving
    • frederikboving
« Reply #2 on: October 04, 2021, 15:42:50 »
I thought coma would point to the center of the frame?
« Reply #3 on: October 04, 2021, 16:19:45 »
Indeed. These must be crops from the lower left corner. The two "wings" point away from the center, and are arranged symetrically around the radius.
« Reply #4 on: October 04, 2021, 20:44:48 »
If I understand correctly, the direction of the coma will depend on the balance of the correction of the related aberrations.
« Reply #5 on: October 05, 2021, 08:12:14 »
Pure coma, without much chromatic aberrations included.
