Author Topic: Nikkor AF-S 28-70mm f2.8D IF  (Read 2270 times)
Gone
« on: September 27, 2021, 10:25:44 »
Anyone know why the filter ring on this lens is sprung? 9 little springs around the three post screws that secure it to the front lens assembly....
Re: Nikkor AF-S 28-70mm f2.8D IF
« Reply #1 on: October 07, 2021, 12:00:59 »
Good question, I have never noticed this, since I never took off the front bezel/filter ring,,,
The 0.8mm of travel is indicated in the sectional drawing here with a text in Japanese.
« Reply #2 on: October 07, 2021, 12:54:19 »
The Japanese word means "designed value".
Is the spring-loaded retaining ring there to avoid any possible warpage of the front-most element caused by the pressure of this ring?  I realize that some high-end filters has the spongy insertion between the filter glass and its retaining ring for this very purpose.
longzoom
« Reply #3 on: October 07, 2021, 13:46:20 »
« Reply #4 on: October 07, 2021, 13:47:35 »
Thank you for the translation!
I will check my lens when I can get to it, but according to the drawings the filter ring is not part of anything regarding retaining the front element assembly directly.
Looks like it's sort of a front decoupler function for when your not using the lens hood as protection,,, Bump protection.
« Reply #5 on: October 07, 2021, 15:33:31 »
You are welcome, Erik.  And you seem to be right.  I Think I didn't read the drawing correctly.
longzoom
« Reply #6 on: October 09, 2021, 19:03:44 »
     As to me, after drawing posted, it may serve for one purpose only - to "click" the hood to its place correctly!  LZ
Gone
« Reply #7 on: October 09, 2021, 22:17:20 »
The hood clicks onto the widest part of the front case - not the filter ring.
Shock protection is the only sensible reason but I doubt how effective it would be.
longzoom
« Reply #8 on: October 09, 2021, 23:48:39 »
   Read the drawing one more time, please. There is no filter ring on the outer part of the main tube. Shock protection isn't the correct explanation. 0.8 mm?? LZ
Gone
« Reply #9 on: October 10, 2021, 01:03:25 »
I don't need to read the diagram - I have the lens and I have disassembled the front to replace a broken filter ring.
To clarify I have marked the section drawing to show where the hood fits, etc.
« Reply #10 on: October 22, 2021, 12:25:47 »
I had a quick look at my lens yesterday - And I can confirm that indeed the lens filtering can slide into the lens housing as the drawing clearly indicate as well, very strange!I tested it as a bumper function and it doesn't work very well, the ring is only able to slide in along the lens axis because of the screws/studs fit tightly inside the holes, so I have literately no clue why it was designed like this.
