Author Topic: [Theme] Pictures taken with vintage lenses  (Read 31070 times)
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
Re: [Theme] Pictures taken with vintage lenses
« Reply #105 on: May 09, 2025, 00:12:37 »
Testing that macro lens, I discover things that are impossible to see with the naked eye, like the two green individuals that appear on the right.
Hans_S
  • Melbourne, Australia
« Reply #106 on: May 09, 2025, 01:50:56 »
1978 35mm f2 AI on a Z6.
Hans Schepers
« Reply #107 on: May 09, 2025, 07:14:57 »
Aphids.
« Reply #108 on: May 10, 2025, 21:11:01 »
OK, here are two images taken with a vintage lens -- Kowa 55mm f/0.8 -- probably harking back to the '60s. Camera is Z fc.
As photographers, we need to keep in mind to work *with* not *against* the tools we have at hand. As such, there never is just a single, "correct" image of any subject. I'd say there are infinite numbers. In this case, the two photos were taken a few seconds apart and both depict the exact same subject.
Is sharpness our only acceptale criterion for a "good" photo? Sometimes, sometimes not. We have the liberty to select any rendition imaginable.
ARTUROARTISTA
    • APM Pintor
« Reply #109 on: May 12, 2025, 21:46:13 »
Birna, translucent images with your signature. I continue with the lens above, seeing results.
ARTUROARTISTA
    • APM Pintor
« Reply #110 on: May 13, 2025, 23:59:56 »
More photos with the lens above, they are of my garden, two unknown beings who live here, and I don't charge them rent.
ARTUROARTISTA
    • APM Pintor
« Reply #111 on: May 14, 2025, 14:53:09 »
Some more, with the same vintage macro
ARTUROARTISTA
    • APM Pintor
« Reply #112 on: May 14, 2025, 15:18:11 »
Another, a little spider, jumping and fussy
Matthew Currie
« Reply #113 on: May 16, 2025, 00:45:01 »
Having trouble posting pictures here. Will try again, pix are within size range.  Favorite old lens, a 200/4 Q from 1963 or 4.  This on D7200 at ISO 1000.  First image is whole shot, downsized, and second is unprocessed crop, just converted to JPG and run through RIOT for compactness.
Now since it's loaded this time I'll add that I have two of those old lenses, both butchered for AI compatibility without undoing the screwed-on flanges, but otherwise working OK.  Not the sharpest tool in the box, but I like the pictures they make, and use one with long extensions for bug hunting.  I was out looking for bees and things when I noticed that tree swallow in the house, so took off the extensions and fired. Using a monopod, sharper results than expected.
« Reply #114 on: May 16, 2025, 09:17:59 »
The 200 Nikkor was a good for for its time. I still use the first "Q" version on occasion for landscape UV.
By the way, you don't need to do such hard jpg compression in order to post... File size around 100Kb is ten to twenty times smaller than required.
ARTUROARTISTA
    • APM Pintor
« Reply #115 on: May 17, 2025, 00:37:51 »
Rosa, photo with Russian cinema lens, year 1971, PO-109-1A 50 mm F1.2
Matthew Currie
« Reply #116 on: May 20, 2025, 00:56:58 »
Not sure whether this would go better in the birds thread or the objets trouvé thread, but since I took it with my nearly favorite lens, the converted pre-AI 35/2.8  PC, I'll put it here.  Clearly this is a mother bird, protecting her clutch of eggs.  Given her former participation in a Japanese microscope, and that she has taken up residence on the wood stove, I must assume she is a chimney Swift!
Thomas Stellwag
« Reply #117 on: May 20, 2025, 09:22:20 »
Thomas Stellwag
« Reply #118 on: May 20, 2025, 18:10:46 »
You're a keen ornithologist, Matthew!
