Author Topic: February 2019  (Read 62237 times)
Re: February 2019
« Reply #105 on: February 10, 2019, 16:44:22 »
Raining-raining and raining
Fuji IS  17-35/2.8  720nm   - changed
Re: February 2019
« Reply #106 on: February 10, 2019, 17:29:06 »
The tower of "Vor frue kirke" was open to the public today, weather not the best ;)
Nikon Df Nikkor-O 35mm f2.0 @f5.6
Re: February 2019
« Reply #107 on: February 10, 2019, 17:40:38 »
This must be Nørrebro, i wonder do i remember this? From where did you take this shot Bent?
Re: February 2019
« Reply #108 on: February 10, 2019, 17:47:37 »
The picture is taken from the tower of Vor Frue Kirke, the dom in Copenhagen. The church in the picture is the German church Sankt Petri. I think that Nørrebro is in the distance hiding in the rain ;)
Re: February 2019
« Reply #109 on: February 10, 2019, 19:00:07 »
A quick test this morning with my new Broncolor 1600 Ws studio flash, using a single flash head at 1 m distance with a wide reflector. I used a UV-Nikkor 105mm f/4.5 lens on my D3200 with internal Baader U filter and shot at f/10, ISO 100 with the flash output turned down 2 stops.
This flash has an uncoated Xenon 1600Ws tube and a clear quartz protector. It run on mains A/C. I could have used a narrower reflector but was curious to learn what exposure levels could be obtained on a wider scene. The reason for the f/10 setting was that I also compared this capture (in terms of exposure) with that of the 25mm f/2.8 Laowa Ultra-Macro Lens 2.5-5X, which is effective f/9.8 at 2.5X.
I also included a patch painted with the Black 2.0 flat black paint (Culturehustle by Stuart Semple).to understand its UV properties. The patch is the smaller of the three circular objects. Also included is some dry Plumeria (assumed to be very UV dark) and my UVEX lab goggles (hopefully they would be UV-dark as well).
The test scene is this,
and it is obvious the Black 2.0 really holds up well in UV too. Same can be said for the UV protective goggles.
Later, I found the Laowa lens needed +2 EV re the UV-Nikkor, which is actually very good, but I don't think its UV response go much below 380 nm. I do need a more appropriate target for that lens, though.
Re: February 2019
« Reply #110 on: February 10, 2019, 20:11:40 »
Always a treat to see your tests  :)
   Walkaround today with z6 and 35mm 1.4 ais. Almería. Weighted down.
Re: February 2019
« Reply #111 on: February 10, 2019, 20:15:23 »
UV setup
Interesting setup Birna.  I guess this demonstrates that UV Photography is a bit more complicated than IR.
Changed the Day pic by the way.  (Still raining)
Re: February 2019
« Reply #112 on: February 10, 2019, 22:02:57 »
February 10
Rainy day
D850  18mm f/4
I thought this was very nice, reminds of the music of the Fläskkvartetten.
Re: February 2019
« Reply #113 on: February 10, 2019, 22:07:41 »
Nice photos!
At the beach taken with 35 1.8 Dx
much better in this orientation. Good use of a good lens
Re: February 2019
« Reply #114 on: February 11, 2019, 07:34:49 »
The Master and Apprentice
I received a call on Saturday from the guy with all of the gear, Master, saying great wind for Kite Surfing the last two days so headed for the beach.  Unfortunately no wind .  Really wanted some action Kite Surfing  >:(
Sony a7iii/FE70-200 f4
Re: February 2019
« Reply #115 on: February 11, 2019, 11:22:58 »
the scans are great but the quality of the originals can be soso, esp since my copy of the Ai 1.4/50mm Nikkor was quite f*cked when I originally bought it in 1988. It suffered a lit of abuse since then. Here is a Fuji Sensia 100 ASA @100 with the much better 1.8/85D in the year 2000 in Sardegna:
Re: February 2019
« Reply #116 on: February 11, 2019, 15:52:39 »
Frank, this is an amazing "insect view" shot!
Re: February 2019
« Reply #117 on: February 11, 2019, 16:26:44 »
Gebruary 11
The weather lend itself for IR shooting, thanks John.
Re: February 2019
« Reply #118 on: February 11, 2019, 16:30:37 »
You'r welcome
Sunny at last
Re: February 2019
« Reply #119 on: February 11, 2019, 16:40:39 »
In retrospect I am not soo amazed about my choice of focus point
