Author Topic: Nikon D750 and 28-50 Ai-s lens  (Read 7584 times)
phlash46
« on: November 04, 2018, 18:43:20 »
Have set it up in non-CPU section as 28mm and f/3.5, but, I cannot change the aperture from f/8 in A mode. ???
Re: Nikon D750 and 28-50 Ai-s lens
« Reply #1 on: November 04, 2018, 20:01:12 »
Did you select the aperture on the aperture ring and it is stuck?
« Reply #2 on: November 04, 2018, 20:07:44 »
You do have selected the correct non-CPU lens entry? If so, the aperture read-out should change when the aperture ring on the lens is rotated. That is,*if* you have set up the camera to use the aperture ring and not the default, viz. the camera dial.
« Reply #3 on: November 04, 2018, 20:13:09 »
Birna: I guess he tries to select aperture from the dials
« Reply #4 on: November 04, 2018, 20:17:06 »
Too many users never realise what the default configuration entails on their Nikons. This again leading, inter alia, to nonsensical statements about the aperture ring being superfluous or non-functional on a modern Nikon. All modern Nikons except the most lowly D3xxx-D5xxx models support the alternative configuration in which you are are allowed to set aperture directly on the lens (if the lens has an aperture ring, of course; otherwise, the camera falls back to "G" lens mode).
One additional reason for getting "stuck" on a single aperture is the camera is in P program mode, thus changing the shutter speed not the aperture value.
