Author Topic: Looking for very low distortion wide-angle  (Read 3307 times)
philipus
  • Film photographer
    • Philip Dygeus photography
« on: June 16, 2018, 08:36:52 »
Hello all
I'm looking for a MF wide-angle lens with no/very low distortion for my FM3A. Currently I have a 24/2.8 AI which I find has too much barrel distortion for architecture, interiors etc. Thanks a lot for any suggestions.
Philip
philipus.com
Film is Photography
Re: Looking for very low distortion wide-angle
« Reply #1 on: June 16, 2018, 09:12:01 »
I often use the Zeiss 25/2; it exhibits little distortion at infinite, but much more at close range (most lenses do that).
The Sigma 24/1.4 A is an excellent lens, and has even less distortion it seems. Since it is relatively bulky, it is not my favourite when paired with the Df, but it is certainly worth considering. MF is easy, but I doubt the FM3a would be able to control the aperture (there is no ring).
Pricewise, a used 25/2 is about the same as a new 24/1.4, but it is difficult to call a Zeiss lens "used", given their build quality.
If you are picky about distortion at a certain range, I can do a quick test (brickwall-style).
I did not mention the 24/3.5 PC, which has a different use case. It is not distortion-free either, but pretty good. Probably not compatible with your camera (the E version has an electronic shutter), but you may find the non-E version used and that one is fully manual.
« Reply #2 on: June 16, 2018, 10:05:26 »
The Sigma 24/1.4 is a G lens, so not suitable for the FM3a. Among Nikon manual focus wide lenses, the AI 28/2.8 and AIS 28/2.8 have the lowest distortion. They are different lenses, both are fine at infinity, the AIS does better at close range as it has CRC.
The late pre-AI K 35/2.8 and AI 35/2.8 serial no 851001 - 870xxx also has low distortion but it's probably not wide enough.
The AI 15/3.5 also has low distortion, but it's a much bigger and wider lens, more expensive too.
Toby
    • Toby Marshall
« Reply #3 on: June 16, 2018, 10:14:38 »
Maybe not your preferred solution, but DxO optics corrects distortion for specific lenses on specific bodies. PS also does not do a bad job unless your lens has mustache distortion.
« Reply #4 on: June 16, 2018, 10:43:36 »
But applying distortion correction in PP is difficult with film cameras ;)
« Reply #5 on: June 16, 2018, 11:06:08 »
AI or later AI-s, the 15mm f/3.5 rectilinear was a dream lens for architects  (how to make that small entrance look like a palace :-) )! Too bad it had a heavy price and wasn't easy to find (sigh).
« Reply #6 on: June 16, 2018, 11:30:04 »
Hello all
Philip
the 1.4/24G is very very well corrected geometrically
« Reply #7 on: June 16, 2018, 12:15:43 »
but it is a G lens, unsuitable for an F3
« Reply #8 on: June 16, 2018, 13:50:02 »
I noticed that too late. The Zeiss is a good Alternative
« Reply #9 on: June 16, 2018, 16:23:52 »
Philip, have you tried the Ai-converted Nikkor-N C Auto 24/2.8?
I used to use one on my Nikon FE loaded with Kodachrome 25 and wasn't bothered by the distortion.  But, when my friend showed me some slides shot with his Ais 24/2.8 on Nikon F, I was surprised to see the clearly noticeable distortion.
« Reply #10 on: June 16, 2018, 19:36:11 »
The Nikon zoom AF-S 17-35/2.8D, when used at 22mm-24mm has surprisingly little distortion.  A wide angle lens with SLR back focal distance that has zero distortion is a very tall order.
Off topic:  The lowest distortion I've ever seen on 35mm film was shot on Leica M film cameras using Leica, Zeiss, and Voigtlander M-mount lenses.
« Reply #11 on: June 17, 2018, 04:54:46 »
LAOWA (Venus Optics) offers "Zero-D" super wideangle 12mm/f2.8:
https://www.venuslens.net/product/laowa-12mm-f2-8-zero-d/
I haven't tried it, so this is just info, but apparently the F mount model can be able to use with the film SLRs.
Netr
« Reply #13 on: June 18, 2018, 11:49:56 »
The Sigma 20/1.4 has limited distortion.
« Reply #14 on: June 18, 2018, 11:50:50 »
again, not F3 compatible ;)
