Author Topic: The fallacy of using long lens technique (LLT) at slow shutter speeds  (Read 35123 times)
Sachtler DA 75L or the Speed-Lock models if you want to support heavier stuff, even the smaller 75mm bowl units in the ENG series.
http://www.sachtler.com/products/tripods/
If you go to the 100 mm bowl units, prices start to climb *fast*.
Ask Erik about Gitzo, I haven't had my own since mid 1980's.
As to head, make a list of the essential requirements first, then try to match these to a given model.
In the Gitzo range series 3 is the start for steady shots you get good steady support, for long night exposures I would recommend series 5 it also has much less twist even fully extended,
The Gitzo 3 and 5 holds a Burzynski inside the tripod spider for extreme stiffness and I would also add spikes.
Kim Pilegaard
  • "Nikea"
Berlebach has a "ballhead" http://www.berlebach.de/?bereich=details&id=22&sprache=english, that resembles the Burzynski head somewhat. Does anybody have experience with that?
Kim
Kim
I don't know this head, it looks like it is very similar in design although only one screw for tension...
Plus the angle of tilt is more limited ...
that being said, it surely looks an interesting alternative to the now nearly unobtainable Burzynski head.
Kim Pilegaard
  • "Nikea"
Re: The fallacy of using long lens technique (LLT) at slow shutter speeds
« Reply #20 on: September 05, 2015, 09:20:02 »
I bought the Berlebach LEVELLING ADAPTER 33° Ø 100 MM/4 ". My first impression is that it is very well made, and that the ball is very big (100mm Ø). It fits nicely on my Gitzo 5532 LS. The head has a separate friction control screw. The big ball makes it easy to position even with a heavy load like the D800 with battery pack and a 500/4 AFS VR lens. It is much bigger than the Burzynski head, but lacks the ability to pan. When I have gained more experience with the head, I will post a longer "review".
Kim
