Author Topic: 28/2.0 AIS needing infiniy stop adjustment  (Read 2087 times)
« on: January 28, 2016, 23:22:57 »
I've got a 28/2.0 AIS Nikkor that needs a minor adjustment of the infinity stop. It doesn't quite focus to infinity. I've done this adjustment a couple of times on a 50/1.4 AIS with no trouble but I can't get a standard precision screwdriver into the screws that lock a brass washer that locks the infinity setting at a proper angle. Is there a special tool for this. Are there screwdrivers with a bend in the shank for this purpose. The screw driver I was trying to use was given to me by a camera repairman friend. I think it was made by Canon and sold by http://www.micro-tools.com/. The screwdriver uses interchangeable blades.
Thanks for any help locating a tool.
Re: 28/2.0 AIS needing infiniy stop adjustment
« Reply #1 on: January 29, 2016, 11:20:09 »
You need to remove the front part of the focus ring and the filter ring...
« Reply #2 on: January 29, 2016, 18:31:45 »
I'm quite sure that's what I did but a screw driver can't be inserted in the screws without an angle that would likely strip the screw's head, screw driver or both. The job was easy to do on a 50/1.4 AIS.
« Reply #3 on: January 29, 2016, 20:13:42 »
Please post an image of that ;)
I have a couple of screwdrivers with extra thin shafts, but should not be needed as I recall,,,
« Reply #4 on: January 31, 2016, 11:25:57 »
I don't have the lens open at this time. I'll have to return to this when I have more time. I think the front element is wide enough to cover the screws that lock the focus ring to the focusing group. The best angle I could get was about 15° which I thought would be enough to strip the screw heads.
