Author Topic: [Theme] Show Birds  (Read 466044 times)
elsid
Re: [Theme] Show Birds
« Reply #585 on: January 11, 2019, 17:40:34 »
The new 500mm PF on the D500.
Nasos Kosmas
  • Athens, Greece
« Reply #586 on: January 11, 2019, 18:49:45 »
Nice, you got it finally?
elsid
« Reply #587 on: January 11, 2019, 19:27:56 »
Hello Nasos, yes I did.
Nasos Kosmas
  • Athens, Greece
« Reply #588 on: January 11, 2019, 20:49:45 »
Lucky guy! now you are armed and dangerous   ;)
enough
  • Anything wild
« Reply #589 on: January 11, 2019, 22:03:08 »
A Yellow-tailed Black Cockatoo preening in the backyard, showing off its namesake feathers
Mark Doro
« Reply #590 on: January 14, 2019, 11:14:45 »
Hi Elsid, can you advise how much you had to crop the image posted?
We'd also be interested in how you've found the practical aspects of using this new PF, things it lets you do you couldn't before etc
elsid
« Reply #591 on: January 14, 2019, 18:36:13 »
Hello Colin,
The image I posted is about 60% of the original, ISO 200, speed 1600 at 5.6.
The lens behaves like the 300 PF, I find the AF relatively fast and accurate, I use it handheld and, for the money, is a good buy. Due to a lucky coincidence
I paid 2,700 e for a copy used once or twice.
It is my first lens at this focal length and I can shoot from distances I could not do before. If you shoot wildlife (and close ups)
It is worth the expenditure,as I find it produces very good results. I have not tried the 1.4x TC on it yet, but at f/8 AF and quality will suffer a bit.
The image below is uncropped.
« Reply #592 on: January 14, 2019, 18:47:20 »
Hi Colin,
just in case you've missed it, here my first i'pression on the 500/5.6 PF: http://nikongear.net/revival/index.php/topic,8037.0.html. Pictures are not cropped nor processed. Most are handheld in rather low light.
Nasos Kosmas
  • Athens, Greece
« Reply #593 on: January 14, 2019, 21:41:43 »
Elsid I find your images a little soft..
« Reply #594 on: January 18, 2019, 07:41:26 »
Just for fun, season has been bad  >:(
Sony a7iii with 70-200 f4 FE handheld
Pied coming up with small fish and a failed attempt  ;)
« Reply #595 on: January 18, 2019, 08:16:38 »
I feel the same.
Seems there are some fine details missing (mostly on the Jay, which is not cropped).
Was the VR on ? Or speed fast enough?
I would find it out using the combo on a sturdy tripod.
Francis.
elsid
« Reply #596 on: January 18, 2019, 20:20:11 »
Speed was 100, aperture 6.3, ISO 3600, hand held. VR on, but at that speed is it relevant?. I took this shot in a hurry, hand holding the camera.
How is the one below?
« Reply #597 on: January 19, 2019, 00:50:04 »
Slightly sharper. :)
Actually the slightest movement of the front lens will amplify as the distance of the subject gets longer.
I always try, when using a long lens combo, to lean against aa firm object like tree, whole or a rock. If there is nothing available, I crouch on one knee holding the front lens, but I use this procedure with my old 500mm AIP, which is certainly a lot heaver than your newer PF lens... ;D
« Reply #598 on: January 19, 2019, 01:08:48 »
Red-breasted Merganser. (Mergus serrator).
Nikkor AFS 300mm F/4 + TC 1.4.
« Reply #599 on: January 22, 2019, 23:24:29 »
Thanks Elsid and Bruno
I like your Jays Elsid, especially the second one.
It seems fair, though is quite a small file so pixelates very quickly when you try to zoom in.
I often get Jays visiting my garden in the spring when they have a young family to feed, but rarely at other times of the year.
http://www.pbase.com/celidh/image/161006365/original
