Author Topic: [Theme] Li'l Flowers  (Read 76316 times)
Gerhard2006
Re: [Theme] Li'l Flowers
« Reply #45 on: April 09, 2023, 07:36:32 »
Little suculents. Nikon J 5 w/105 2.8 micro Nikkor
Gerhard2006
« Reply #46 on: April 09, 2023, 07:44:09 »
More little flowers
Bob Foster
« Reply #47 on: April 09, 2023, 17:03:27 »
Bluets- These can be so common in unused pastures or wasteland to give an entire field a blue cast.
1. Least Bluet. For many years this was named Hedyotis crassifolia though many, perhaps most sources now classify this as Houstonia pusilla.
The flowers are 6-10 mm across and at least in my area almost always are found in groups separate from the clearly larger Houstonia pusilla.
2. Tiny Bluets Houstonia pusilla with one Least Bluet (if indeed there is any difference other than flower size.) The flowers on these are larger about 12-16mm. This image shows the exception- there is one "Least Bluet" in a clump of "Tiny Bluets".
3. Not all Bluets are blue- some are white such as the Southern Bluet Houstonia micrantha.
Bob Foster
« Reply #48 on: April 09, 2023, 17:14:11 »
Field madder, probably Sherardia arvensis. This is a much smaller flower than bluets they average about 2.5-3.5mm. Sometimes I find these a much less saturated color.
« Reply #49 on: April 09, 2023, 20:49:19 »
Gerhard and Bob, these are really pretty collections!
Bob Foster
« Reply #50 on: April 10, 2023, 08:10:24 »
Thank you Akira.
Bob
Gerhard2006
« Reply #51 on: April 10, 2023, 20:22:03 »
Thanks Akira, I wish I had Bob’s knowledge of flowers I just photographed them because of their beauty and delicate precision. Thanks for your descriptions Bob Regards Gerry
Bob Foster
« Reply #52 on: April 10, 2023, 23:07:18 »
Gerry. I appreciate your kind words.
Birna is "our" botanist! If I recall correctly she studied macrophytes (a class of underwater plants) as well as photography.
For me, learning a bit about the flora and fauna that I see and their place and function within our ecosystem simply adds to the wonder that is life.
I'm here largely because I'm very slowly learning to see more, often in unfamiliar ways. From time to time an image posted here gives a feeling of joy to me: diverse though we are such an image speaks to our human commonality.
Bob
Lars Hansen
  • Zealand, Denmark
« Reply #53 on: April 17, 2023, 21:47:09 »
Spring time around here - Blue Violet ... I think.
Bob Foster
« Reply #54 on: April 19, 2023, 15:32:11 »
This pieris was planted over ten years ago along a fence line where it is partially shaded by a tree on the adjacent property. This is the first year it has produced flowers. The foliage is changing from the early spring red to glossy green. The flowers are about 13-14mm.
« Reply #55 on: April 28, 2023, 02:54:39 »
April 27
Ornithogalum umbellatum, the garden star-of-Bethlehem, grass lily, nap-at-noon, or eleven-o'clock lady,
D850  60mm f/2.8
Lars Hansen
  • Zealand, Denmark
« Reply #56 on: May 03, 2023, 20:08:56 »
Li'l flowers popping op along the lakeshore.
Added one more.
Lars Hansen
  • Zealand, Denmark
« Reply #57 on: May 10, 2023, 18:39:47 »
Li'l flowers in the local park lawn.
Lars Hansen
  • Zealand, Denmark
« Reply #58 on: May 15, 2023, 19:00:04 »
A species of Myosotis .. again :)
« Reply #59 on: May 16, 2023, 11:22:33 »
Allium schoenoprasum or chives
