Author Topic: New Nikkor Z 14-24mm f/2.8 s  (Read 1728 times)
  • Fairbanks, Alaska
Re: New Nikkor Z 14-24mm f/2.8 s
« Reply #1 on: September 16, 2020, 10:02:34 »
650g only!
Nikfuson
« Reply #2 on: September 16, 2020, 10:10:32 »
The disadvantage with these new expensive lenses is...too much money involved.
The advantages there are many of.
« Reply #3 on: September 16, 2020, 10:21:27 »
Yes, the suggested retail price is quite high and spoils the fun  :o When the 14-24mm f/2.8 came for F-Mount it was affordable as I recall,,,
I'll be keeping the F-Mount version and even use it on Z7 with the added bonus of having rainbows included in most sunny images  ::)
« Reply #4 on: September 16, 2020, 10:24:27 »
650g only!
Yes that's 300 grams lighter than the F-Mount, substantial
« Reply #5 on: September 16, 2020, 14:09:30 »
Pice incl. vat in Denmark is 2.800,- €
chambeshi
« Reply #6 on: September 16, 2020, 14:22:05 »
MTFs etc
https://www.nikon-image.com/products/nikkor/zmount/nikkor_z_14-24mm_f28_s/spec.html
It is indeed impressive Nikon's engineers have kept the weight to 650g. It will be packaged with 2 lens hoods listed; HB97 takes 112 mm filters, and this zoom can also use rear gel filters.
« Reply #7 on: September 16, 2020, 22:48:07 »
MTF at 14mm is amazingly good, basically a flat line across the top. MTF at 24mm shows some drop-off towards the outer part of the image, but otherwise equally impressive. Looks like an excellent addition to the Z lineup. Not sure who will use 112mm filters with this lens, unless it is protection from salt spray etc.
« Reply #8 on: September 17, 2020, 22:41:28 »
If the distortion aspect isn't bad, this lens is going to be absolute gold.  Z mount really flexing it's potential with this one!  Color me impressed so far.
« Reply #9 on: September 18, 2020, 00:30:45 »
Along with the more humble 14-30/4.0, Nikon's new super-wideangle zooms are literally epoch-making: both allow to use front filters without bizarre adapters.
« Reply #10 on: November 16, 2020, 08:55:38 »
New review and comparison - Comprehensive!
https://www.cameralabs.com/nikon-z-14-24mm-f2-8-s-review/
Looks like it performs very good - Only nitpicks compared to the F-mount version is the back ground Bokeh is not as smooth and the high $£€
« Reply #11 on: November 16, 2020, 10:20:59 »
thanks! probably too long for what i need :o :o :o
i just want a cheap 45/2.8E ::)
