Author Topic: Nikon D6 w super tele lens lineup - new FL lens???  (Read 7894 times)
Re: Nikon D6 w super tele lens lineup - new FL lens???
« Reply #15 on: June 06, 2020, 17:08:32 »
Do you think the "PF" principle will be the new standard for super-teles to make them more compact or do you make some optical compromises using this principle so the real "top-notch" prof. grade super-teles will still be made "old-school"?
« Reply #16 on: June 06, 2020, 18:01:16 »
Yes
Neither will go away.
MILLIREHM
  • Vienna, Austria
« Reply #17 on: June 06, 2020, 18:21:38 »
I agree that there will be two lines remaining - but the old school has changed and is about to change (FL elements, SR elements, new coatings, maybe we will see sapphire glass, more lightweight chassis)
I see it a bit similar to Canons DO that remained limited (400/4 and 70-300/4,5-5,6 -are there more?) and did not replace the superfast high grade lineup
Wolfgang Rehm
« Reply #18 on: June 07, 2020, 16:01:58 »
I'd considered the Z-mount  85 mm f/1,8 S as (slight) tele
Technically, maybe Wolfgang....
But if I want to shoot sports or wildlife, when does anyone think Nikon will release "S" versions of the tools for the job?
Nothing other than zooms yet indicated
MILLIREHM
  • Vienna, Austria
« Reply #19 on: June 07, 2020, 16:20:18 »
As i am operating D4S, D500, D850 and Z6 (amongst others) I'd recommend taking a SLR when shooting sports or wildlife. And there is plenty of superb F-mount tools out there that can be operated on a Z as well without compatibiliy restrictions  via FTZ adapter
we have the Z-mounted 70-200/2,8 S already and there will be more - be patient. Current situatoin has become completely unpredictable due to foreseeable and unforeseeable consequences of pandemic driven economic crisis and severe impacts on an already shrinking market.
Technically everything beyound 50-60 mm up to 200 mm is considered as Tele lens and everything from 300 and above supertele, so 85 /1,8 is tele but of course by no way a sufficient tool for sports and wildlife which requires supertele. Given the Z-roadmap a 100-400 S and 200-600 have been announced, both are in the supertele range - no prime of course but the same goes for the 80-400, 180-400, 200-400 and 200-500 F-mount lenses. And BTW there is no 200-600 lens in the F-mount lineup if its good it may be a winner. To me this strategy is right, prosumers are preferring telezooms and the number of those who aquire FL-type primes is limited.
Personally I might buy the 200-600 but I am not willing to add another 800mm f/5,6 in Z-mount.
Wolfgang Rehm
« Reply #20 on: June 07, 2020, 17:16:43 »
The benefit of short register distance for mirrorless is primarily recognized with short focal lengths. Telephoto designs are likely the same for F and Z mount. We also know that Nikon's autofocus for DSLRs is currently faster than mirrorless. So I'm speculating that they countinue with Tele and super Tele in F mount. Z users can use the adapter.
« Reply #21 on: June 07, 2020, 18:29:37 »
I wonder if a Z super-tele could benefit from having a larger rear element to have the light rays at 90 degree on sensor also in the corners?
Maybe a Z super-tele could also be faster if it is designed with shorter register distance?
« Reply #22 on: June 08, 2020, 03:41:57 »
A larger mount could make possible telephotos with less mechanical vignetting into the corners, but I don't think this has been a serious problem with the F-mount.
I don't see how the shorter register distance would make faster super-teles possible, the flange distance is not greatly relevant for telphotos. Nikon already has fast telephotos for F-mount such as 400/2.8, 200/2 and the old AIS 300/2, I don't think there is much demand for faster (bigger, heavier, more expensive) lenses in this segment. If anything I suspect the trend is towards slower super-teles due to the improved performance at high ISOs of modern cameras - the 500/5.6PF being a good example of this.
« Reply #23 on: June 08, 2020, 03:52:07 »
As you pointed out previously, the shorter flange back could rather be beneficial to the designs of teleconverters and focus reducers.
« Reply #24 on: June 08, 2020, 06:00:55 »
Oh yes, forgot about that :o :)
« Reply #25 on: June 08, 2020, 08:40:50 »
I rather second this. In my small world of car racing competition, ML cameras remain an exception: some Fuji, very few Sony, and no Nikon Z as far as I could notice. My most used lens in 2019, was the 500mm f/5.6E PF, with over 11’000 pictures taken.
« Reply #26 on: June 08, 2020, 12:24:30 »
Looking at this group shot I am wondering about the lens on the far right - is this the upcoming 200mm FL version???
D6 with 120-300mm
from left to right: 80-400, 180-400, 200-400, 800, 600, 500, 400, 300, and ???
Logically it would be the 200mm VRII (which I own) but the lens shown exhibits the updated FL design!
Wondering???
IMO the two lenses on the right are 500pf and 300pf
« Reply #27 on: June 08, 2020, 14:21:15 »
Frank, I don’t think so: the second from the right has a filter slot which (see the button) the 500mm hasn’t.  ;)
« Reply #28 on: June 08, 2020, 14:55:43 »
OK, my bet is that the one on far right is the 300f4 PF and third from right is the 500 f5.6 PF
https://www.downgra.de/Geek/Nikon-500mm-f56E-PF/
Handled them both when Z6 and Z7 introduced in Goa but 300 on the Z7 and 500 on D5.  Deciding if to by 300 PF or AF-P 70-300 or see what is coming.   Cash flow and arrival of Monsoon means no hurry  ;)
MILLIREHM
  • Vienna, Austria
« Reply #29 on: June 08, 2020, 15:10:04 »
The one on far right is having the cone form, the 500 PF has and the 300 PF is lacking - and the 300 PF is smaller
Wolfgang Rehm
