Author Topic: Hello from Copenhagen  (Read 4989 times)
the solitaire
Re: Hello from Copenhagen
« Reply #15 on: March 16, 2020, 19:54:56 »
As to your 35mm, that look sas if the glue holding the lens group together, and holding it in the lens body starts to deteriorate. If that is th ecase, I would advise to use the lans as it is now, because a fix might not be financially viable, unless you fit an optical group from another lens.
The technical camera mounted to the DSLR looks really interesting. I studied photography back in the late 1990's and learned with large format cameras (Linhoff and Cambo) and always missed the real movements those cameras offered.
I think I just got a compromise solution in buying a Nikon PB-4 bellows and a bellows lens, but I still have to wait for the bellows to be delivered.
Anyways, welcome to the forum. From the conversation you stirred up, I'd say you found the right place :)
Buddy
