Author Topic: How can 1000 K be warmer than 5000 K ?  (Read 8700 times)
Re: How can 1000 K be warmer than 5000 K ?
« Reply #15 on: February 01, 2020, 15:37:41 »
There evidently has been a touch-up of nomenclature here.
Degrees Kelvin (depreciated) ---> K  (unit symbol) == kelvin (unit designation)
No degree sign any more.
Nikkor Shooter
« Reply #16 on: February 01, 2020, 16:19:31 »
Not really sure about this, AFAIK when a unit name is derived from the surname of a scientist (Ampere, Joule, Volt, Watt, Pascal, Curie, Ångstrom, Kelvin...) it keeps  the capital. Other uits of measurement do not necessarily have a capital letter (meter, gram, second, hour, ...) Ciao from Massimo
I read as well that it should be written small but makes no sense to me.
JohnMM
Re: How can 1000°K be warmer than 5000°K ?
« Reply #17 on: February 01, 2020, 16:23:34 »
Ciao from Massimo
CERN : https://writing-guidelines.web.cern.ch/entries/units
IUPAC : https://iupac.org/100/stories/the-new-si/
National Institute of Standards ... (US) : https://www.nist.gov/pml/weights-and-measures/metric-si/si-units
JohnMM
« Reply #18 on: February 01, 2020, 23:06:25 »
I'm not sure about the logic either. However use of an upper case initial letter would give the unit the status of a "proper noun". Proper nouns are usually reserved for specific examples. So there is only one Lord Kelvin, the person after whom the unit is named. However there are very many examples which use that unit of measurement, the "kelvin", and here a "common noun", with a lower case initial letter, is used.
« Reply #19 on: February 02, 2020, 22:08:24 »
Whatever the relevant authority tells us is the current usage.... is the current usage.
How about the 'decibel'?
Written:  decibel.  Original unit, the 'bel', is not commonly used.
Abbreviated: dB
Named after:  Alexander Graham Bell, inventor of the American telephone (and other devices).
« Reply #20 on: February 04, 2020, 11:25:23 »
And they go on and write it as kelvin in the text and then Kelvin in the table  ::) omg,,,
JohnMM
« Reply #21 on: February 04, 2020, 12:04:03 »
Which table is that ? Do you mean the list on the left hand side on this page https://www.nist.gov/si-redefinition/road-revised-si ?
This is simply title capitalisation. All units in the list, whether named after a person or not, are given an initial upper case letter.
« Reply #22 on: February 04, 2020, 12:20:46 »
I just think it's interesting/amusing to proofread such texts  ;D There are so many pitfalls and exceptions  8)
Here on this page below, they write it Kelvin in the table although they stress in the text it should be kelvin  ::)
https://www.nist.gov/pml/weights-and-measures/si-units-temperature
Nikkor Shooter
« Reply #23 on: February 04, 2020, 12:30:20 »
The two symbols of kelvin and kilo for thousand
should be the same? "k". no sense to me
« Reply #24 on: February 04, 2020, 13:11:33 »
It's kelvin and then you use as a unit K
So 1,000 kelvin is 1kK
Boltzmann constant is k,,, see why I think this is an entraining sport  8)
« Reply #25 on: February 04, 2020, 13:34:54 »
Yes I get that ;)
Wannabebetter
« Reply #26 on: February 20, 2020, 11:45:57 »
Once upon a time...  :o
The short of it: We were [sic] messing with cyanobacteria and all manner of blind, troglobite amphibians and similar chordates; subjecting them to variable degrees of gain, amplitude and waves of light spanning 380nm to 780nm; controlling or otherwise attenuating ambient room/environmental temperature and barometric pressure (dear Lord!) to within a ridiculously invariable margin; concluding two things. A lot of money was spent spent affirming what any of us would have freely admitted if not held hostage and that we would have much preferred spending our last moments on Earth inebriated. (Someone got a PhD or a p-h something or another. Bath salts? Anyway the algae were happy. The salamanders weren't saying, but I could tell blue was the new black in their world.)
