Author Topic: Nikkor 24mm f/2.8 Ai-S Repair!!!  (Read 7268 times)
Re: Nikkor 24mm f/2.8 Ai-S Repair!!!
« Reply #15 on: November 05, 2020, 16:07:58 »
For the small set screws it's very important to have a screwdriver tip that fits perfectly.
Hollow ground is the best way to go also for all other flat screws on lenses - I grind the myself from a slight oversize one.
Gunsmiths use them as well.
Precision hollow ground is the strongest!
do you grind it by hand? :o :o :o
i think i need another one.
i broke mine, the metal was too brittle ::)
« Reply #16 on: November 05, 2020, 16:26:10 »
Yes, with a small Dremel grinder.
