Author Topic: September 2019  (Read 173896 times)
Re: September 2019
« Reply #45 on: September 04, 2019, 19:52:47 »
Managed to ruin the xqd cardreader and damage an xqd card.
Meh.
creative reading?
Re: September 2019
« Reply #46 on: September 04, 2019, 20:03:46 »
Thank you, Bent hope your cars is all set to go again.
Thank you Frank the sony reader is broke the cards get stuck inside, damaged my one card on trying to get it out.
Need to leave my cards inside the cameras and use the sd's as backup.
Re: September 2019
« Reply #47 on: September 04, 2019, 20:03:57 »
Thank you John.
I see the Z6 is in heavy use. A lot of fine pictures. Both from the library and this.
Thanks Bent
Meh.
Nice Graphics.
How did you manage that?  Which Sony reader you have?
Re: September 2019
« Reply #48 on: September 04, 2019, 20:22:48 »
Sony MRWE90 XQD/SD Card USB 3.0 Reader
i took it with me on holidays all i can think i may have become damaged in the bag
the cards get stuck inside the reader and dont pop out
so i had to pry it out where one card plastic frame got damaged
still usable but best left in the cam i think
these 64gh xqd cards are pricey
Re: September 2019
« Reply #49 on: September 05, 2019, 14:51:54 »
Thanks for the warning, Fons.  Indeed, these cards are too expensive.
I was under the impression the XQD system was more robust than the SD cards (I never had a failure). Apparantly it's not...  Or is it just the writer which can be vulnerable?
Re: September 2019
« Reply #50 on: September 05, 2019, 17:59:55 »
It's not easy to focus the 35/1.4 in the wide open position. It's hard to determine the exact point were the focus is. A better focus-screen does hardly help. Shoot and check the image afterwards was regularly necessary.
How different the situation with the Nikon Z6 were the zoom in the viewfinder is a big help.
Nikon Z6  35/1.4 Ai-S           ISO 100  f/1.4  1/25 Sec
Re: September 2019
« Reply #51 on: September 06, 2019, 16:13:03 »
September 6
3 images stitched and edited
D850, 24-70mm f/2.8
Re: September 2019
« Reply #52 on: September 06, 2019, 16:58:29 »
The main square behind Central Station
Z6  35/1.4 Ai-S
Re: September 2019
« Reply #53 on: September 06, 2019, 18:02:14 »
I did cook again...
Lamb, Safranreis, grilled veggies, 2015 organic Bordeaux
Re: September 2019
« Reply #54 on: September 06, 2019, 18:23:27 »
I did cook again...
Fine looking dish :)
Re: September 2019
« Reply #55 on: September 06, 2019, 19:02:08 »
September 6
D850, 24-70mm f/2.8
Very nice and dramatic  :)
Re: September 2019
« Reply #56 on: September 06, 2019, 19:47:33 »
Thank you Bent
Re: September 2019
« Reply #57 on: September 06, 2019, 23:29:34 »
Something that I actually hadn't seen before, a duckweed (Lemna turionifera) with fruit. During the last couple of years I have examined thousands of those tiny duckweed fronds. Typically the entire floating frond is 1.5-3mm, and 5-6 times I observed and photographed flowering plants. Of course these species have the most efficient vegetative propagation imaginable, yet genetic recombination through sexual means might become useful in a changeable climate.
Shot with Z7 and the Laowa 25mm f/2.8 Ultra-Macro lens at 5X magnification, some 20 frames stacked with Zerene. The frond is approx. 1.7mm on the major axis, to indicate what scale we are at.
Re: September 2019
« Reply #58 on: September 06, 2019, 23:44:13 »
Very impressive, I wonder why it is called Red Duckweed in Danish? Is it because of the red tint on the fruit? The leaves are green, right?
Re: September 2019
« Reply #59 on: September 06, 2019, 23:56:24 »
The fronds can be suffused with red in the autumn. However, other duckweeds can attain the same colours, so I don't think the Danish name is very apt.
A duckweed is morphologically highly reduced and specialised thus there do not exist leaves in the ordinary sense.
