Author Topic: July 2018  (Read 76942 times)
Re: July 2018
« Reply #225 on: July 27, 2018, 10:51:10 »
A classical sunset...
Re: July 2018
« Reply #226 on: July 27, 2018, 11:18:47 »
A real beauty, Jacques!
Re: July 2018
« Reply #227 on: July 27, 2018, 11:37:35 »
Thanks a lot  ;) I’ve been testing the use of my Df with only a iPad Pro and a wi-fi « My Passport » hard disk for backing the files. It works well, even with the Nef files (latest firmware from WD!).
I like the gain of weight vs the Macbook.
Re: July 2018
« Reply #228 on: July 27, 2018, 11:52:10 »
Whit this set up, your files are on the hard disk and you access them with the iPad, via wi-fi. They dont have to get through the Photo App, but can be used directly through Snapseed (or else),then, when modified, saved in Photo App.
On the « cloud » WD software you can see the jpeg and Raw files and choose which to bring on the iPad to edit.
You can also use Affinity Photo or other softwares, without getting in the paying « Clouds » of Lightroom or even Apple.
You keep the usual file size you’ve set your camera to.
I like the « mobility » of the process, while ensuring your files are backed up (the hard disk has an SD slot and copy the files automatically)...  8)
Re: July 2018
« Reply #229 on: July 27, 2018, 13:24:06 »
there is available also a cardreader for i-pad and -phone
Re: July 2018
« Reply #230 on: July 27, 2018, 13:26:19 »
July 27
Burgwal Oss
D500 18-140mm f/3.5-5.6vr
Re: July 2018
« Reply #231 on: July 27, 2018, 13:28:23 »
A happy marriage of beautiful scene and amazing composition!
Re: July 2018
« Reply #232 on: July 27, 2018, 16:39:57 »
Beautiful classical sunset.
Re: July 2018
« Reply #233 on: July 27, 2018, 17:04:02 »
my wife wants fresh veggies for my birthday Party. I will eat the Gazpacho and hold onto the cold beverages...
Re: July 2018
« Reply #234 on: July 27, 2018, 17:20:13 »
Congratulations Frank !.
A hot day, close to 38 degrees Celcius. Even hot on a bicycle...
D600  85/1.4
Re: July 2018
« Reply #235 on: July 27, 2018, 17:26:31 »
Thanks Akira and Golunvolo  :)
Fons, while I have those extensions, the main purpose was not to load files in the iPad but on a 2 Terabyte support. Thinking maybe at long distant trips  ;)
Re: July 2018
« Reply #236 on: July 27, 2018, 17:32:47 »
Happy birthday Frank
Re: July 2018
« Reply #237 on: July 27, 2018, 17:58:30 »
Mediterranean life and colors by the sea
Peter Forsell
  • A Cunning Linguist
Re: July 2018
« Reply #238 on: July 27, 2018, 18:24:08 »
Taking the earthworm for a swim
20180727-_DSC1351c by foppa2011, on Flickr
Re: July 2018
« Reply #239 on: July 27, 2018, 18:44:55 »
Very nice Peter, which fisheye and cam here?
