Author Topic: new PF Nikkor telephotos? patent for 400, 500 & 600  (Read 10494 times)
Re: new PF Nikkor telephotos? patent for 400, 500 & 600
« Reply #15 on: February 03, 2018, 16:37:56 »
OPTIA is a measurement device, not a simulator.
It is good to remember none of these f/5.6 PF lenses are products and if Nikon do make such products, they may or may not be like what is described in the patents.
Personally I don’t like to use TCs; although sometimes I get excited after testing them, over time I’ve never really liked images shot with TCs. The crispness of detail is lost, AF performance becomes more erratic, there is like a slight veil over the image. I am much happier not using them. For a while I shot deer with the D5, 300 PF and TC-14E III, and felt that sharpness was almost but not quite there, and in waning light the AF focused a bit here and there. Then I started to shoot more without TC and it was quite a ”Wow! Where did all this crisp fur detail come from?” experience. And I was using a D5 not even a high resolution body. With the 2X the 300 PF couldn’t focus at all in typical light I would have for these subjects (deer, moose), unless put on tripod and LV focused.
So I feel definitely there is value in a 400/5.6 for someone who doesn’t like the results from TCs. Someone who has a 300/4 might not buy a 400/5,6 but a 500/5,6, and another person might prefer the 70-200 & 400/5,6 for a more clear difference between lenses. Using a modern digital camera one can easily crop those in-between distances/framings and spacing lenses with some gap in between means one can get a variety of shot types without too much overall bag weight and easy hiking. I sometimes pair the 105 and 300 for similar reasons.
It is nice to see Nikon finally consider offering a range of apertures also for prime lenses with AF-S like they did in the manual focus era. Perhaps they have reduced spending on more 18-xxx DX lenses and are able to use more of their resources on specialized high end products.
I think of these, the 500/5,6 would be of the most interest to me. This is because it would have a nice gap from my existing lenses and sufficiently different. A second hand 500/4 is also a competing option.
JKoerner007
« Reply #16 on: February 03, 2018, 21:02:19 »
The 2x TC III came out right when the 300 f/2.8 VR II came out; it was designed for f/2.8 lenses or wider (200mm f/2 VR II, 300 f/2.8 VR II, and 400 f/2.8 FL ED), not for other lenses.
Therefore, using the 2x extender on the 300 f/4 PF is misuse of the 2x TC III. (Sure, you can try, but the lesser 300mm is not the lens the 2x TC III was designed to complement.)
  • "While this teleconverter works with any professional Nikon lens that can take teleconverters, it is specifically designed to work with fast prime lenses with an aperture of f/2.8 and larger."
    ~ Taken from Photography Life
That said, I have seen many, many people post superb images with the 300 f/4 PF + 1.4 TC III
(With the proper 1.4x TC III, the 300 f/4 PF becomes a ~420mm f/5.6 equivalent on FF ... or ~630mm f/5.6 equivalent on DX).
On the other hand, the 2x TC III turns my D500 + 300 f/2.8 VR II into an equivalent 900mm f/5.6 ... that is easily as sharp or sharper @ 900mm with the 2x TC III as the 300 f/4 is @ 630mm with the 1.4 TC III 8)
Regarding the subject of image quality, it is pretty much common knowledge that TCs produce some image degradation.
However, the key thing to realize is you're hoping for "acceptable" sharpness, in exchange for the added reach, rather than "absolute" sharpness.
So, yes, if you want "absolute" sharpness, then don't use TCs.
However, if you want to dramatically-increase your lens reach, then 1) follow the instructions and use the right TC for the right lens, and 2) don't expect "absolute" sharpness.
Instead, be grateful you are able to get "acceptable" sharpness + far better reach that you could not have gotten otherwise with your bare lens.
Here are some bird images I obtained with the 300mm f/2.8 VR II + 2x TC III at an equivalent 900mm on the D500.
They may not be the sharpest images in the world, but they are definitely "acceptably" sharp:
Black-Headed Grosbeak ♂ by John A. Koerner II, on Flickr
Red-Whiskered Bulbul by John A. Koerner II, on Flickr
Northern Mockingbird by John A. Koerner II, on Flickr
Mourning Doves by John A. Koerner II, on Flickr
Had I not had the 2x TC III, and tried to crop-in to the same compositions, they would not have turned out as well.
As a nature hiker, I would much rather have 300 VR II + 2x TC III, where I can keep the lens mounted on my gimbal head (and switch between TC, or no TC, to halve or double my reach) than I would to carry a bare 300mm lens, and a bare 600 mm lens, respectively, and try to alternate between these to halve or double my reach :o
The only better option for maximal range/minimal gear would be the recently-introduced 180-400mm f/4 FL ED + 1.4x TC (equivalent 270-840 on DX).
Jack
JKoerner007
« Reply #17 on: February 03, 2018, 21:37:16 »
But today’s DSLR landscape has changed the markets for telephotos of slower speeds. Not only do the exotic Nikkors perform very well with TCs but so does the 300 f4 PF, and the 70-200 zooms (but a bit of a stretch). I often use my 200 f2G VRII as a hefty but well balanced 400 f4 with TC2 III. I find this combo that much easier to handhold than the equally excellent 300 f2.8G with TCs. And the 200+TC2 gives the better IQ and AF performance on the D500 and D850... but I do so wish for a lighter prime of 2 kg and even lighter. The 400 f5.6AIS is a nifty 1.2kg :-)
I agree with this. Compatibility with a TC should not be overlooked in the construction of a super-tele lens.
I would love to see a 400mm f/4E PF, which would be an equivalent 840mm lens with a 1.4x TC + D500, but weigh about half what my 300mm f/2.8 weighs.
A 600 f/5.6E PF would translate to a 1260mm f/8 with the same TC + DX combo.
Really heavy, fast super-telephotos are for shooting from blinds, boats, or vehicles ... they're not much fun to hike with.
I think the 300 f/4E PF is a great little lens, and I am continually-tempted to trade my 300mm f/2.8 II for it, just to enjoy the weight loss. With the 1.4 TC III the image quality is equivalent to the 300mm VR II with the 2x TC III. What I don't want to do, however, is give up the 270mm reach advantage my combo has. With the TCs off, the 300mm VR II is a hands-down better lens than the 300 f/4 PF, but again the weight is a hassle on very long hikes.
I could certainly live with the image quality of the PF lens ...
Especially while enjoying every hiking moment a lot better with a 1.7 lb (.755 kg) lens in the 300 f/4 PF ... as opposed to trudging through each hike with the 6.39 lb (2.90 kg) lens in the 300mm f/2.8 VR II :o
fish_shooter
    • Salmonography.com
« Reply #18 on: February 04, 2018, 21:31:26 »
I am skeptical that a 400/4 PF lens would be that light. The current Canon 400/4 DO (i.e. PF) and 300/2.8 lenses are respectively, 2.1 and 2.35 kg. Maybe you have a custom made steel-shelled 4+ kg 300/2.8 II? The 300/2.8 VRII is <3kg. Keep in mind that the patent is for a 400/5.6 lens. That would indeed be much lighter than a 300/2.8. Since the current 300 PF lens plus 1.4 TC is a 420/5.6 lens that would be a better guesstimate for size. The other two are 5.6 lenses as well so the lens elements will have to be  larger, especially the 600. The 600/5.6 will be more like a 300/2.8 in diameter.
PS. Very nice bird shots esp the one with the two doves!!
MILLIREHM
  • Vienna, Austria
« Reply #19 on: February 04, 2018, 22:31:58 »
From the users perspective, there can't be enough options. But Nikons production capacities are limited. Will there be enough revenue for Nikon in a difficult economic situation and increasing pressure by competitors. There are good and rather compact and lightweight Zoom lenses 80-400 and 200-500 out there. So will there be enough space between those and the FL series lenses for a successful product placement? I don't know.
The PF primes may have more TC-usability  but Personally I am findng myself with decreasing use of TCs although I still carry them around.
BTW.: I'd like to have a 400/3,5 successor with AF that is as compact and lightweight as the old AI-S lens
Wolfgang Rehm
JKoerner007
« Reply #20 on: February 05, 2018, 05:11:25 »
The 300 f/2.8 VR II is 6.39 lb (2.9 kg).
The 300 f/4 is 1.7 lb (.755 kg), or less than 25% of the weight.
However, with the 2x TC III, the 300 f/2.8 VR II is able to deliver equal or better quality @ ~ 900mm to what the 300 f/4 can deliver with the 1.4 TC III @ 630mm.
The question thus becomes, "What is more important? A 4.7 lb (2.15 kg) weight reduction? Or a 270mm reach advantage?"
There is no right answer; each has powerful pros/cons.
« Reply #21 on: February 05, 2018, 05:17:06 »
Last I checked:
300 x 2 = 600
300 x 1.4 = 420
600 - 420 = 180
Looks like the 600mm PF has already colonized your imagination.
JKoerner007
« Reply #22 on: February 05, 2018, 06:31:41 »
Last I checked:
300 x 2 = 600
300 x 1.4 = 420
600 - 420 = 180
Reading thoroughly is so important ...
600 x 1.5 (DX) = 900
420 x 1.5 (DX) = 630
900 - 630 = 270
I was calculating the 1.5 crop factor of the D500.
« Reply #23 on: February 05, 2018, 06:38:04 »
900 - 630 = 270
Sorry, I didn’t see anything in the post mentioning d500 crop factors.
Also, I don’t believe in crop factors. Focal length is focal length. I started out with medium format, then played with 4x5, so 1.5 crop factor has little meaning.
« Reply #24 on: February 05, 2018, 09:08:47 »
I don't know what the correct figures are but if Nikon's sales has been reduced by 1/2 of what they were in the peak years, they should a lot of presently unused production capability available if there are interested buyers for the products that they can make. Since Nikon is not making as many consumer products now they can perhaps offer a greater range of high end offerings. I recall in 2005 (?) they stopped the manufacture of many lower volume lenses and my reading of the explanation for doing so was to make production capacity available for the great number of 18-200mm lenses that customers wanted to buy. That situation seems to have passed.
What is good and compact is debatable. I sold both zooms quickly; each had some issues. The 300 PF on the other hand I keep and it is among my most used lenses.
I wouldn't have high hopes for TC-ability of f/5.6 teles, PF or not; Nikon AF at f/8 s something that may work in some circumstances, but not all that well in dimmer light or for low contrast subjects. The 300/2.8 is especially good with TCs, but it is a special lens (one which Nikon is aware is often used with TCs so they design both that lens and their TCs accordingly).
I see the value of the f/5.6 PF teles in comfortable hand-holdability without inducing significant fatigue even over longer periods of use, which might be true of the 80-400 but not so much of the 200-500. Of course people have different requirements for hand-holdability, and physical build, but I would set the requirement at comfortable hand-held continuous use for 2-3 hours. If my arms are not shaking after that and if there is no pain anywhere, then I would consider the lens hand-holdable. Of course the 300 PF passes with flying colors.
f/2.8 and f/4 FL teles have 1-2 stops larger aperture than these proposed f/5.6 PFs and as refractive optics they should have better bokeh and likely focus faster than any f/5.6 lens. They however require much greater expenditure and plenty of people can not afford them, and might not even want them because of the size and weight.
Anyway, each of us have our own requirements, it is nice to see a potential broadening of offerings from Nikon.
JKoerner007
« Reply #25 on: February 05, 2018, 16:12:16 »
It was there. Again, it's not that you didn't see, it's that you didn't read.
Focal length is focal length, but framing is framing.
Choosing only to believe in one side of the equation (focal length) is your prerogative, but choosing not to acknowledge the other side of the equation (the effect of crop factors), is a failure of sorts because this definitely affects the outcome. (I am surprised this doesn't have more meaning to you, with your past experience.)
Similarly, choosing not to read before you comment is your prerogative as well, but it does tend to throw a wrench into things.
Back to the point: a 300mm lens on a D5 might not be quite enough reach ... while the same lens on a D500 might create perfect framing ... and yet a 300mm lens might be overkill on a Micro 4/3rd.
Same focal length, different crop factors, different results.
What is there "not to believe" ?
« Reply #26 on: February 05, 2018, 16:47:52 »
Don’t want to argue with you. You have your opinion and I have my facts :-)
I do believe when a number is expressed in a common unit which is intrinsic to the object being described, that it doesn’t get converted. A shoe does not become a larger size just because it is placed on a smaller foot. That is the whole purpose of standard units.
You can choose to use whatever means of communication you like, but it is more likely to be mis-understood than sticking to standards.
Please take my posts - all of them - as friendly. I’m not here to argue. I’m sure we both have better things to do.
MILLIREHM
  • Vienna, Austria
« Reply #27 on: February 05, 2018, 17:19:45 »
If Nikon can afford it they can produce it - but its risky as there is high uncertainty whether there will be enough mid to high-end buyers for a complete PF series
Wolfgang Rehm
JKoerner007
« Reply #28 on: February 05, 2018, 18:01:11 »
Ahh, so your beliefs are facts, mine "opinion," that's very convenient ;)
That is an invalid comparison.
I understand what you're saying, focal lengths are focal lengths, but the other "fact" is how sensor size will affect the framing of your composition.
This is every bit as inexorable a "fact" as the focal length.
Actually, I think the rest of the world understands my meaning just fine ... as do you.
In fact (since you appreciate facts), the DX conversion is directly advertised in the new Nikkor 180-400mm advertising by both BH Photo and by Nikon itself:
  • "Built-in 1.4x teleconverter allows you to instantly extend your reach to 252-560mm (or 378-840mm equivalent with DX cameras) simply by flipping the right-hand switch."
    ~ B&H Photo
  • "Capture sports, events and wildlife in lifelike brilliance from 180-400mm, then, without breaking shooting posture, engage the integrated teleconverter and increase your reach to 560mm f/5.6 (840mm equivalent on a DX body)."
    ~ Nikon USA
Is there anything left to debate? :)
Sure, let's keep it friendly (we don't have to "argue," we can debate :) )
Let me end our friendly debate by saying, the manufacturer itself acknowledges the changes in "equivalent focal lengths" of its own lenses, based on the FX and DX bodies it too manufactures, so I think my point has been made.
Have a good one,
Jack
« Reply #29 on: February 05, 2018, 18:51:05 »
    ~ B&H Photo
    ~ Nikon USA
Have a good one,
Jack
Wow!
