Author Topic: [Theme] leaves  (Read 189605 times)
Lars Hansen
  • Zealand, Denmark
Re: [Theme] leaves
« Reply #390 on: November 27, 2020, 21:02:49 »
Ordered trees with disordered leaves.
Re: [Theme] leaves
« Reply #391 on: November 28, 2020, 00:02:16 »
I like the rhythmic placement of the trees and the way the green line gives some accent to the image.  Well done!
Re: [Theme] leaves
« Reply #392 on: November 28, 2020, 19:51:46 »
Frosted strawberry leaves. Could equally well have been placed under "black and white", of course.
Jacques
Re: [Theme] leaves
« Reply #393 on: November 28, 2020, 20:03:22 »
A.Jacks
Re: [Theme] leaves
« Reply #394 on: December 09, 2020, 14:59:17 »
Re: [Theme] leaves
« Reply #395 on: December 11, 2020, 10:06:26 »
Re: [Theme] leaves
« Reply #396 on: December 11, 2020, 10:08:17 »
Kind of neutral.
Re: [Theme] leaves
« Reply #397 on: December 11, 2020, 12:07:16 »
I like this pleasant atmosphere.
Quite seasonal...
Akira to the point.
Re: [Theme] leaves
« Reply #398 on: December 11, 2020, 13:46:31 »
Nice leaves  :D
Tehnically a leaf rather than leaves as the thread title suggests, but anyway. I was bored and decided to stick an lcd panel behind a leaf and focust stack the heck out of it  ;D. I liked the resulting pattern.
Re: [Theme] leaves
« Reply #399 on: December 12, 2020, 06:49:34 »
HiCon leaves
Lars Hansen
  • Zealand, Denmark
Re: [Theme] leaves
« Reply #400 on: December 12, 2020, 18:42:29 »
A late, but big thanks, Akira! I'm glad you like the composition with the lines - I also noticed the slightly lighter yellow line when I took the shot. I'm not a musician like you, but maybe a fugue is hidden in that rythmic placement of the trees  :)
Re: [Theme] leaves
« Reply #401 on: December 12, 2020, 20:01:06 »
Simply red.
Re: [Theme] leaves
« Reply #402 on: December 13, 2020, 00:03:14 »
Birna, strawberry frost super texture and monochromatic composition
Jaques, colors! Super Heroes work here or are they hiring? :)
Fons image of time going with the times.
Akira´s neutral is so quietly poetic.
Hans details sinuous and organic roads. Great detail isolation.
Akira, again, poetic but this time in a harmonic way, if that has any meaning to you.
   Here, night leaves with night lights.
  Z6, 50mm 1.8s
Re: [Theme] leaves
« Reply #403 on: December 13, 2020, 01:09:35 »
Thank you, Paco.
The purple fringe of the light and magenta leaves resonate nicely.
Re: [Theme] leaves
« Reply #404 on: December 13, 2020, 07:11:49 »
Gradient leaves.
