Author Topic: not so much a wedding-wedding  (Read 10599 times)
Re: not so much a wedding-wedding
« Reply #15 on: July 08, 2015, 16:33:06 »
here is the thread about flash usage
http://nikongear.net/revival/index.php?topic=673.0
Cheers
« Reply #16 on: July 08, 2015, 20:01:08 »
It's easy to see that they had a great time.
This also reminds me that I have promised to take some photos at some friends wedding in a few months and my knowledge of flash is about as good as yours, if not worse...I'm signing up for Armando's crash flash course immediately!  ;D
« Reply #17 on: July 09, 2015, 06:52:06 »
You go Jørgen :)
« Reply #18 on: July 09, 2015, 17:47:55 »
Very lively images!
You say you are so not a wedding photogrepher possibly because you don't like the order of ceremony which is a great cliche.  Wedding photography is important for sure, and you have a solid technique to do that, but your artistic mind keeps you from doing that...
« Reply #19 on: July 09, 2015, 18:23:37 »
Thank you Akira
« Reply #20 on: July 09, 2015, 22:02:31 »
Elsa, like I mentioned in the topic started by Armando these were my default flash settings:
- Manual exposure to control the background (try first without the flash)
- Flash on TTL to let the camera determine subject exposure
- Flash at second curtain
- Starting point with flash exposure compensation was usually -1.67EV to make things blend a little bit
So in essence you control the background exposure and let the flash figure out the subject exposure based on subject distance (this was what the D in AF-D was for), light reflection, etc.
The minus 1,67EV flash compensation was my starting point to tone the flash a bit down and was easily fine tuned with cams that have a flash compensation button, never fully got the hang to the SB800 menus because I rarely used a flash (moved to a SB400 later for the just in case situations).
