Author Topic: Special Adapter  (Read 5428 times)
Re: Special Adapter
« Reply #15 on: August 23, 2017, 23:52:07 »
The older AI and AIS 105/4 micros are excellent, also the AIS 105/2.8. All are relatively cheap on the used market and are much more common than the Voigtlander 90mm.
Re: Special Adapter
« Reply #16 on: August 24, 2017, 00:19:04 »
Why not a CV Apo Lanthar 2.5 125mm in Nikon mount? Prices have fallen massively last months...
AOr is this too long FL?
Bern
Re: Special Adapter
« Reply #17 on: August 24, 2017, 03:40:00 »
Thank you again! I will keep on searching for the perfect macro lens for my D810. A 90mm would be perfect and also 100mm but I am hesitant for the Zeiss Makro-Planar.
If a 90mm focal length is important, Tamron also has a 90mm f2.8 macro. I use the older 2nd generation AF non stabilized version sort of like a hybrid of a nikkor G and D lens. It has no aperture ring but not AF-S. Switching from AF to MF is by pulling the focusing ring and vice versa for engaging the AF. The front does not rotate but extends when focusing at close distance similar to the 105 AF D. It also feature a focus limiter which can be handy at times. The front element is also well recessed in the barrel but it comes with a bayonet type hood for added protection.
The newer versions has image stabilization and the lens does not extend when focused at close distances anymore.
Keep shooting,
Bern
Gigas
Re: Special Adapter
« Reply #18 on: August 24, 2017, 21:10:28 »
That would be a nice lens but to close to my Zeiss 135mm 2,0.
Re: Special Adapter
« Reply #19 on: August 24, 2017, 21:26:14 »
Too close but "No cigar" as I read.
I'm not privileged to own either.
Gigas
Re: Special Adapter
« Reply #20 on: August 24, 2017, 21:26:45 »
Here is another shot taken with the Zeiss 135mm 2,0 and Polaroid 250D + Canon 500D. Next step is to isolate the background more.
https://flic.kr/p/XRTfxY
Re: Special Adapter
« Reply #21 on: August 24, 2017, 21:27:10 »
+1
Re: Special Adapter
« Reply #22 on: August 25, 2017, 03:56:35 »
There are two ways to do this:
1. Use a wider aperture, but then your depth of field on the subject gets too narrow.
2. Use a longer focal length. This narrows the angle of view so you get less of the background in, and what is in the frame is blurred more.
The Zeiss 135mm with a closeup filter will have a combined focal length nearer 100mm. You could try using an extension tube if you need to focus closer than the lens allows. This will reduce the focus distance without reducing the focal length.
Another option is to buy one of the longer macro lenses, such as the AFD 200/4 micro, or Tamron 180/3.5.  These have internal focusing (IF) so the focal length reduces at close range, so it might not end up being much of an improvement over your Zeiss 135. Might be worth exploring. Or try an AFS 300/4 with extension tube, as discussed here: http://nikongear.net/revival/index.php/topic,6255.0.html. This will give you a very long, close-focusing lens with narrow field of view, should be very good for isolating the subject from the background.
Gigas
Re: Special Adapter
« Reply #23 on: August 25, 2017, 12:03:04 »
I have tried extension tubes but did not like the results. With the Zeiss 135mm 2,0 and Polaroid 250D and Canon 500D. I gets down to 6-10 inches of WD so that is fine. The main problem is to get DOF that will cover the entire shrimp!
Re: Special Adapter
« Reply #24 on: August 25, 2017, 12:35:06 »
For really good results with tubes you need a unit focusing lens like the old Micro-Nikkor 105mm f/4 or the 55mm f/3.5.
The modern CRC or IF design- lenses with floating elements, don't do well with extension tubes!
Gigas
Re: Special Adapter
« Reply #25 on: August 25, 2017, 14:16:52 »
I use the 105 bellows lens with the 105mm 4,0 stacked with good results but quite often a little bit to short WD. This idea came from Bjørn!
Re: Special Adapter
« Reply #26 on: August 25, 2017, 15:37:35 »
In an earlier thread on macros the Micro Nikkor Ai-S 4/200mm was recommended to me. I bought it and use it with very pleasing results, esp the Color fidelity is superb.
The PF 4/300 takes extension very well and features stabilized shooting and VR on top of great optical performance see examples. I will soon provide examples with longer extension.
PS. I love your shrimp shots!!!!
Gigas
Re: Special Adapter
« Reply #27 on: August 27, 2017, 13:19:02 »
Thank you Frank Fremerey! I will hunt for a 200mm micro lens and try that!
