Author Topic: Carl Zeiss Jena Biotar 58mm f/2 (picture heavy!)  (Read 22273 times)
Re: Carl Zeiss Jena Biotar 58mm f/2 (picture heavy!)
« Reply #30 on: May 16, 2020, 08:31:45 »
If your lenses are M39 thread and made for Russian SLR like my version they can only be used for close distance on a F-mount body. But using a M39 to M42 ring (it is a ring without any flange) and then a M42 adapter for Z-mount it can focus to about 10m or so.
There is a direct M39-Z adapter   https://www.kentfaith.com/KF06.389_m39-lenses-to-nikon-z-mount-camera-adapter
« Reply #31 on: May 16, 2020, 08:53:25 »
I have one of those adapters. It is for LTM (like Leica rangefinder lenses) and it works perfect using a e.g. Jupiter-8 50/2 lens which is a rangefinder lens. But the M39 Helios 44 I have is not a rangefinder lens but a SLR lens so register distance does not fit using the adapter above. Some additional distance is needed.
« Reply #32 on: May 16, 2020, 13:19:28 »
I found out with some google search the different lens registrations:
M42 adapter: 45.46 mm
M39 Soviet SLR lenses: 45.2 mm
LTM (39 mm): 28.8 mm
T2 adapter: 55 mm
The above confirms using a M39 Helios-44 using M42 adapter via a M39-M42 ring that it is 0.26 mm from reaching infinity focus.
Petr sheepeck Jůza
« Reply #33 on: May 19, 2020, 00:10:05 »
Should I go or not..... Small boy pondering following his older brother.  :-)
Petr sheepeck Jůza
« Reply #34 on: May 22, 2020, 22:31:04 »
Swirly character.
CS
« Reply #35 on: May 22, 2020, 22:55:19 »
Is that a glass background, or am I looking at lens bokeh?
Carl
« Reply #36 on: May 22, 2020, 23:58:52 »
Those are beautiful portraits. Marks the character and emotions.
Petr sheepeck Jůza
« Reply #37 on: May 22, 2020, 23:59:26 »
Bokeh. There is a tree on the right side. The bark looks interesting, doesn’t it?
CS
« Reply #38 on: May 23, 2020, 00:31:40 »
Yes.
Carl
Mimsie
  • You ARE NikonGear'23
« Reply #39 on: April 30, 2025, 08:39:27 »
Taken with a manual 17 blades model on D700 at the longest end of the focus which was around 2 meters
« Reply #40 on: April 30, 2025, 14:40:55 »
Helios-44-2 on Zf
« Reply #41 on: April 30, 2025, 20:42:14 »
Quote from: Petr
I really like ypur two portraits Petr
Welcome aboard Mimsie
« Reply #42 on: April 30, 2025, 23:39:58 »
Another Helios 44-2 on Zf. Wide open and at minimum focussing distance, central sharpness is pretty high, which is uncommon. Also, the vignetting is reasonable. On the downside, LoCA is conspicuous (see the green fringing) and off-center sharpness is low.
I'd be curious to see how the revised Biotar (58/1.5) by Meyer Görlitz behaves in comparison.
« Reply #43 on: May 01, 2025, 07:00:32 »
The "old style" of the sculpture and lens rendering work together!
F2F3F6
« Reply #44 on: May 01, 2025, 18:42:30 »
Nice rendering for the Carl Zeiss Biotar (first model).
The Helios 44 2,0/58 is a nice lens, a good copy of the Biotar, but you can find many "wobbling" Helioses, the first ones being aluminium bodies. I prefer the 44 K the last model for construction, but it's the one with multicoating that is more bulky, and alas, with less swirly bokeh...with only 8 straight aperture blades, the oldest had more (10 ? 12 ? I don't remember...)
You can't always win ! A nice copy of Helios 44M black or 44K can be found for 50-80 € here in France ! Works good with Nikon Z : Zfc or Z50 give you a "85mm equivalent" portrait lens or o a Z fullframe a nice 58mm, the poor man's Noct or neonoct !
Enjoy !
