Quote from: Erik Lund on June 02, 2017, 11:04:55
For the 45mm 2.8 Ai-P It might be worth a try to make a combined lens hood and focus ring for improved/wider manual focusing ring width,,,
yes. that is a good idea! I am doing that with my W-Nikkors for RF, as you know they can be a pain to turn (aperture ring)
i also intend to have numbers engraved on it as soon as I learn how to do it with precision.
a step-down ring was my initial choice until I learned about the Haas Mini Mill
Interesting suggestion. One possibility is to modify a Nikon bayonet lens hood with its internal diameter close to fit over the 45 AIP focusing ring (outer dia of my lens, the black model is 60.4mm). It must be narrow to not block the distance scale, or better indented for that section.
This mod would be along the lines of HK-3 - the great accessory for the 20mm f4AI. The locking screw tightens a spring steel ring around the rubber grip of the focusing ring. (The HK-3 is scarce but well worth the search if one is committed to the 20 f4.)
