Author Topic: el-nikkor  (Read 13298 times)
Re: el-nikkor
« Reply #30 on: December 21, 2017, 23:25:17 »
I don´t know about the inner design but the 80mm 5.6, metal barrel, is the most versatile -with 20 to 40mm helicoids- That young man´s portrait in this page was taken with it. The detail in combination with the d750 I like a lot
Re: el-nikkor
« Reply #31 on: December 21, 2017, 23:50:38 »
With better information I'd have bought an 85/5.6 EL-Nikkor or 75/3.5 or 4.5? Fuhinon-EP enlarging lens. I'll have to correct the specs on the Fuji lens when I'm at my computer.
The classic advice was don't scimp on your enlarging lenses. When you buy fine taking lenses and then use one economy enlarging lens you loose the primium performance you paid for with the taking lenses, from my experience this is very true.
I'm not as sophisticated regarding lens design and performance as many here and I'm self taught so a lot of what I know comes from trial and error. For example I waned a shorter extension tube than a PK-11 for years but over looked the K-Ring set mentioned on Bjørn's legacy Website as old fashioned.
chambeshi
Re: el-nikkor
« Reply #32 on: December 25, 2017, 08:16:15 »
Just published Thousand and One Nights No.64 - EL-Nikkor 80mm f/5.6N
http://imaging.nikon.com/history/story/0064/index.htm
Re: el-nikkor
« Reply #33 on: December 25, 2017, 11:53:21 »
Cannot more than agree, excellent choice the 5.6/80mm is, the older 5.6/105mm being a close 2nd!!
Re: el-nikkor
« Reply #34 on: December 25, 2017, 13:33:47 »
Thank you for the tale. First one I’ve ever read. They are fantastic 😳
  Some useful info with the “Therefore, green to yellow focus positions that humans use for focusing and the violet focus position must all be the same. What's more, good aberration compensation throughout the entire visible spectrum is necessary for color enlargements. As a result, EL-Nikkor lenses were designed with consideration of a broad range of wavelengths, from near ultraviolet at 380 nm to near infrared at 700 nm.” popping out.
  My version of the lens it’s the one with metal barrel
Re: el-nikkor
« Reply #35 on: December 25, 2017, 13:38:18 »
  You recomended it. Thanks for the pointer Dr. Klaus. Images in the 105mm/28mm cpu modification were taken with that same lens and adapter
Re: el-nikkor
« Reply #36 on: December 25, 2017, 18:03:46 »
Most welcome, great you like it!
Wonderful for multispectral work, as the individual images perfectly fit to combine images!
Here my famous "Psychedelic Lily" taken with the 5.6/80mm EL-Nikkor, a UV-VIS composite
Re: el-nikkor
« Reply #37 on: December 26, 2017, 13:14:09 »
That is very interesting. Great results! I have seen some of your work with visible, invisible and combinations but have never seen this specific image.
  Thanks for sharing it!
Re: el-nikkor
« Reply #38 on: December 26, 2017, 14:35:16 »
If I remember correctly, the UV performance of chrome-base 105/5.6 is better than 80/5.6 from the same period: the 105/5.6 shows practically no focus shift in UV.
Re: el-nikkor
« Reply #39 on: December 28, 2017, 19:55:45 »
I need an uv camera  8)
Re: el-nikkor
« Reply #40 on: December 28, 2017, 22:37:12 »
Easy, ask me...!!
Re: el-nikkor
« Reply #41 on: December 29, 2017, 00:16:31 »
...my famous "Psychedelic Lily" taken with the 5.6/80mm EL-Nikkor...
I like it!
