Author Topic: Lens "porn" with the Df: The 105 mm Nikkors. Part 2  (Read 104427 times)
Wannabebetter
Re: Lens "porn" with the Df: The 105 mm Nikkors. Part 2
« Reply #30 on: July 16, 2021, 13:21:54 »
I am duly impressed with the images produced by that 105 mounted on the Df. Moreover, I would die a happy man if only I could spend the remainder of my years living on that houseboat on the water.
Luc
    • Flickr
« Reply #31 on: July 16, 2021, 22:46:26 »
Df + 105mm f2.5
« Reply #32 on: July 17, 2021, 08:09:43 »
Lovely image Luc.
(It is really nice to see a young man reading printed matter - without his head buried in a bloody cell phone!  :) )
Luc
    • Flickr
« Reply #33 on: July 17, 2021, 19:17:31 »
Thanks Hugh. And I agree upon the reading.
Michael Hopferwieser
« Reply #34 on: November 05, 2023, 19:31:04 »
Sad Thoughts.
toups
  • You ARE NikonGear'23
« Reply #35 on: March 08, 2025, 04:03:52 »
A little late to the party and I don't have a Df, but I do have a 105 mm f/2.5 pre-AI lens that I have been found very enjoyable.
I purchased it for a fair price, but it wouldn't focus properly, one of the helicoids was jammed.  Thanks to Richard Haw's website, I was able to disassemble and get it back together again and working quite nicely.  I AI modded it for use with a D50 and D70 that I had at the time and added a Dandelion chip.  Since then I acquired a D610.
I have two pre-AI lenses I modified, but this is the only one with the metal scalloped focus ring. It's a shame they didn't keep the metal focus rings and moved to the plastic/rubber rings.
This is the 6 aperture blade variant with a min aperture of f/22.
« Reply #36 on: March 08, 2025, 08:34:09 »
Well done! Happy shooting!
toups
« Reply #37 on: March 08, 2025, 12:57:56 »
Thanks.  As you can see, 2 screws are now "missing" and need to be replaced.  Basically the heads were destroyed when trying to remove them.  Tried all the normal tricks (heat, solvent) without luck.  I believe I ended up having to drill the head off of one. Since these are straight slot versions, the need for a JIS screwdriver wasn't involved. ;D
