Author Topic: seeking advice on (relatively) lightweight 35mm lens for travel  (Read 10806 times)
PeterN
Re: seeking advice on (relatively) lightwieght 35mm lens for travel
« Reply #15 on: December 08, 2016, 19:16:06 »
any thoughts on the 35mm 2.0 AF-D that is still sold new?
Peter
« Reply #16 on: December 08, 2016, 19:35:23 »
Too plasticky for my taste. Not totally convinced about its optical performance either.
« Reply #17 on: December 08, 2016, 21:10:45 »
The 35/2.8 K is superb with the Df, so probably would to good service on a D750 too. It has very low geometric distortion as far as wide angles go, another trait in its favour.
Be warned you will need to get hold of an AI-modified (by factory kit preferably) lens.
Does the K model have the same optics as the AI?
I found the 35/2.0 AI made a superb normal lens for my D300s and I like it on my D800 though I've used AF-D and AF-S lenses more than AI and AIS lens on my D800.
« Reply #18 on: December 08, 2016, 21:18:52 »
Somewhere along the road the superb 'K' optics (6/6)  of the 35/2.8 was replaced by a more mundane design (5/5). Probably shaved off a few $$ in the production costs to please the ever busy bean counters, but th magic was lost.
« Reply #19 on: December 08, 2016, 21:19:15 »
There are two AI 35/2.8 models:
The first is the same as the K model with 6-elements, serial nos 851001 - 870063
In late 1977 or early 1978 it was replaced with the 5-element version, serial nos 350001 - 459942. The same optics were used with the AIS version.
Use this as a reference: http://photosynthesis.co.nz/nikon/lenses.html#35
« Reply #20 on: December 08, 2016, 21:55:56 »
For travels, I now use a really good little lens : the 36-72mm f/3,5 serie E.(AIS) It is slightly bigger than a 35mm prime but you get more range of focals. It weights 375gr (a manual 35mm nikkor weight about 225gr) and is very sharp.
But perhaps you want only primes ?
Below, an image taken yesteday with DF and this little zoom @36mm.
« Reply #21 on: December 08, 2016, 22:02:39 »
The picture didn't like the compression hence these moiré effect.
BW
    • Børge Wahl-Photography
« Reply #22 on: December 08, 2016, 22:14:20 »
I can vouch for the 36-72 as well. An exellent little zoom on the Df.
PeterN
Re: seeking advice on (relatively) lightweight 35mm lens for travel
« Reply #23 on: December 09, 2016, 09:14:04 »
I will definitely look into these.
Thanks for sharing your views and experiences! I now have multiple options to look into.
So far I have: 45P, ultron 40, 35 1.4 ais, 35 2.0 ais, 35 2.8 K (851001-870063), 36-72 3.5 E.
It is also helpful to know that the 35/2 AF-D is too soft on the newer dslrs/
Peter
« Reply #24 on: December 09, 2016, 09:26:19 »
 The 35/1.4 any version does well on all cameras. This behaviour extends to the newest AFS model, however, it is no longer conveniently small.
« Reply #25 on: December 09, 2016, 09:38:33 »
The 35/2.0 K or AI have a longer throw on the focus ring than the AIS version which may help with manual focus on a DSLR.
I'd be inclined to go with an AF-S 35/1.8G on a D750.
« Reply #26 on: December 09, 2016, 09:47:53 »
The 35mm 1.4 Ais fits the bill, small lightweight, does fine wide open with slim dof as well as stopped down. No need to look any further.
PeterN
« Reply #27 on: December 14, 2016, 17:13:40 »
just wanted to let you know I ended up buying the 35mm 2.8 AI (same optics as K) with serial number 851965.
It came with a working Nikon FE, which I planned to use as a prop for my watch photography. But now I am thinking about buying a few rolls and shoot with it. Just for fun.
Thanks for your help!
Peter
« Reply #28 on: December 14, 2016, 17:20:37 »
I'm sure the community would love to see some results with that lens in due time ...
PeterN
« Reply #29 on: December 14, 2016, 17:26:00 »
I will sharesome results
Peter
