Author Topic: Nikkor 105mm 1.4 AFS E Compared to Nikkor 85mm 1.4 AFS  (Read 14668 times)
Re: Nikkor 105mm 1.4 AFS E Compared to Nikkor 85mm 1.4 AFS
« Reply #15 on: October 05, 2016, 22:03:31 »
Albino Pine,,,
_EGL6979 by Erik Gunst Lund, on Flickr
Interesting rendering of the pale branch lower left,,, circle after circle - Interesting.
« Reply #16 on: October 05, 2016, 22:11:55 »
Amazing slim slice of depth of sharpness is cut out in this dry tree,,,
_EGL7034 by Erik Gunst Lund, on Flickr
Outstanding performance - I have done almost no processing on this one,, they just come out like this,,, a very nice tool in the 1.4 G line of lenses!
longzoom
« Reply #17 on: October 05, 2016, 22:46:25 »
Thanks a lot, Erik, for your efforts for all of us! I definitely know now what should I wait from that new toy! Thanks again! LZ
« Reply #18 on: November 02, 2016, 09:33:14 »
So Roger at LensRentals has now done some measurements and comparisons also to the 85mm AFS 1.4,,, He likes the new 105 AFS 1.4
https://www.lensrentals.com/blog/2016/11/nikon-105mm-f1-4-e-mtf-bench-tests/
PeterN
« Reply #20 on: November 03, 2016, 16:35:12 »
tempting. very tempting. How is the weight and handling on a D810?
Peter
« Reply #21 on: November 03, 2016, 18:15:51 »
It handles like a charm if you have the battery grip mounted, It works for sure also without just not as well balanced
Lens hood is loose by design, so needs a pice of a zip tie in one of the holes.
« Reply #22 on: November 03, 2016, 18:35:41 »
Well I was told its not a good buy and a waste of money (says my bank manager - but what does he know)
 ;D ;D I shall not be tempted
stenrasmussen
« Reply #23 on: November 03, 2016, 18:40:54 »
The lens hood on my 58G is also loose...I don't like that.
« Reply #24 on: November 03, 2016, 18:46:15 »
The 58 AFS 1,4 G got two small screws since it has short holes, all the other 1.4 G lenses has long holes.
stenrasmussen
« Reply #25 on: November 03, 2016, 20:21:47 »
Whaaat? I cannot see any screws...tis all just plastic and some slots and tabs.
« Reply #26 on: November 03, 2016, 20:30:50 »
Erik meant the measures to be taken in order to stop the hood from falling off.
Short holes => run small screws through them
Long holes => cut a suitable piece of plastic strip (zip ties are perfect) and insert into the slot
stenrasmussen
« Reply #27 on: November 03, 2016, 20:37:42 »
Ach so...
Just jammed a tiny rubber band (meant for braces on teeth) in one of the bayonet slots and yes, Bob's me uncle  ;D
« Reply #28 on: November 04, 2016, 08:52:28 »
Not quite so, I drilled two new small holes, one on each side of the hood right where the locking tap is on the lens hood.
Here is a shot of the screw
_EGL2390 by Erik Gunst Lund, on Flickr
Here is the tap from the inside, the screw now acts as an extension of the tap.
_EGL2377 by Erik Gunst Lund, on Flickr
MILLIREHM
  • Vienna, Austria
« Reply #29 on: November 10, 2016, 23:40:32 »
Nikon where are you going
A lens likethat and a loose lens-hood (just similar as the superteles with unusual tripod foots)
Wolfgang Rehm
