Author Topic: AF-S Nikkor 105/1.4E to be announced  (Read 94883 times)
Re: AF-S Nikkor 105/1.4E to be announced
« Reply #135 on: August 04, 2016, 22:23:02 »
Quite a few Nikon lenses have shifted production from one country to another, you can see this detailed here: http://photosynthesis.co.nz/nikon/serialno.html
For example the AFS 105VR micro started production in Japan, later moving to China
The AFS 60mm micro started in Japan, moved to Thailand, back to Japan (possibly due to the flood a few years ago) then back to Thailand
The 18-105 and 15-140 both started in Thailand, now made in China.
And many others...
However I very much doubt we ever had the same lens made in two locations at the same time.
Going back to the 105/1.4, I have added the specifications to my site.
« Reply #136 on: August 05, 2016, 00:46:12 »
Thank you Akira & Roland 😊
« Reply #137 on: August 05, 2016, 12:35:41 »
I am looking forward to test drive the thing one day.
Everybody sure there is no VR?
« Reply #138 on: August 05, 2016, 15:38:55 »
VR lenses have "VR" in the lens name and barrel.
chris dees
  • Amsterdam
« Reply #139 on: August 05, 2016, 16:40:27 »
Sorry Frank, the sample I had was without VR.
Chris Dees
« Reply #140 on: August 05, 2016, 18:13:30 »
I was curious bwcause it is so huge...
Anyone knows the weight? More that one kilogram I guess?
« Reply #141 on: August 05, 2016, 20:26:29 »
985g.  All specs can be had on Nikon's official website now.
« Reply #142 on: August 05, 2016, 20:39:13 »
We can safely assume there is a lot of plastic material inside it, then. Hopefully some reinforced carbon fibre variety to give robustness.
The glass alone must make up the better part of the total weight.
« Reply #143 on: August 06, 2016, 00:38:14 »
The 105/1.4 appears to have an outer plastic shell similar to lenses like the AFS 85/1.4. Overall the size and weight is similar to lenses like the 135DC and AFS 24-70, so I expect a similar mix of materials in the constuction.
« Reply #144 on: August 06, 2016, 01:25:08 »
I have the impression that Nikon is trying to reduce the weight of newer lenses.  Most notable examples are the f1.8 wideangles which are very light for their significantly larger sizes compared to the old Ai AF f2.8 lenses.  I also remember that I was quite surprised by the (light) weight of 16-35VR zoom.
The AF-S lenses like 24-70/2.8VR, 85/1.4 or the new 105/1.4 couldn't be light because, as Bjørn noted, their lens barrels are stuffed with thick or many optical glasses.
« Reply #145 on: August 06, 2016, 04:12:53 »
I see, the official announcement is there. I ask NPS for a sample.
Andy
« Reply #146 on: August 07, 2016, 18:41:49 »
Roland,
I had the chance to handle it for a few minutes. A few things I memorized:
The 105mm/1.4 looks like and handles like a beefed-up AFS 85mm/1.4G. The difference is more tangible on the diameter, less on the length. With the hood, the length of the AFS 105mm/1.4 vs. the AFS 85mm/1.4G is about 4cm longer. The tactile feeling is very similar between the two lenses (on material, grip, buttons). The major differences on the tube are the golden characters "1.4G" vs. "1.4E ED", the inscription "M/A" and "M"  and the white dot (finding the proper mounting position) is larger on the 105.
Dismounted, the AFS 85mm (a "G" lens) keeps the blades on the smallest aperture f16, the 105mm "E" keeps it open at f1.4. Looking through the front lens, there is a direct view on the inner imprint of the LF-1 "LF-1 Made in Japan".
While the weight is similar to the 135mm DC, the ratio diameter:length there is very different. Also the material.
With the AFS 24-70mm VR, the material seems to be more or less identical, but the "missing" diameter of the 24-70 creates a very different handling experience.
On a single digit body with the AFS 105mm, the combo handles "balanced".
BTW, it has 4+ screws (in your terminology), s/n is 7 digits.
rgds, Andy
« Reply #147 on: August 08, 2016, 10:38:35 »
Thanks Andy, I will add the new details to my list. I don't suppose you remember the serial number, or if it is indeed made in China?
Andy
« Reply #148 on: August 08, 2016, 11:31:23 »
..... or if it is indeed made in China?
Yes, it is listed as "Made in China"
« Reply #149 on: August 13, 2016, 18:19:21 »
scheduled to test this lens next week. :o :o :o
