Author Topic: Projection lenses  (Read 179507 times)
Re: Projection lenses
« Reply #450 on: March 03, 2021, 22:10:37 »
Lovely lens and examples. First one is most impressive.
Thanks John!
« Reply #451 on: March 03, 2021, 22:15:31 »
Meopta STIGMAR 1.4/100mm
« Reply #452 on: March 17, 2021, 09:07:17 »
Zeiss Jena VISIONAR f1.6/141mm
« Reply #453 on: March 27, 2021, 08:01:29 »
Zeiss Jena VISIONAR 141mm
Toby
    • Toby Marshall
« Reply #454 on: May 25, 2021, 01:28:03 »
I'm not buying many lenses these days, but I did pick up a Kinon Superior I 5cm f1.8. Very interesting lens indeed. Unlike all the other shorter Kinons (5cm Superiors and 5cm Superior f1.6, and 65mm Kinon) this lens does not have swirly bokeh. Instead it has very strong bokeh. The lens covers about 80% of FF focused at infinity, about 90-odd percent at 1 meter, and covers the full frame at close distances. It is very sharp in the center of frame, albeit with some highlight halation, and though it is uncoated, is much less prone to flare working against the light and ghosting than most other projection lenses of the era that I have used. Here are some examples, post-processed, but not radically so. Some sharpening, contrast and clarity adjustments.
F2F3F6
« Reply #455 on: May 25, 2021, 19:14:36 »
Sharp...and dreamy ! Interesting lenses these "Kinon Superior" ! And well done, the pictures are really interesting...(portrait or flowers)
« Reply #456 on: May 26, 2021, 18:27:21 »
Very nice Toby! I like your processing skills!!
« Reply #457 on: May 27, 2021, 08:33:57 »
A very special bokeh and rendering.
« Reply #458 on: May 27, 2021, 13:39:56 »
+1 and you know how to use it.
  Very interesting work. The first image with the hand is fantastic. Oleeee
Thomas Stellwag
« Reply #459 on: May 27, 2021, 14:52:22 »
+1
Thomas Stellwag
Zang
« Reply #460 on: September 15, 2023, 02:11:28 »
My first ever projection lens :)
Zang
« Reply #461 on: September 15, 2023, 02:14:50 »
And the lens adapted.
« Reply #462 on: September 15, 2023, 09:19:02 »
Looks very neat!
Thomas Stellwag
« Reply #463 on: September 15, 2023, 14:01:58 »
I like the tools, you used to mounted it  :)
Thomas Stellwag
Zang
« Reply #464 on: September 15, 2023, 21:26:03 »
