Author Topic: Ai Conversion of an old 5cm f2 Nikkor-S  (Read 12322 times)
Re: Ai Conversion of an old 5cm f2 Nikkor-S
« Reply #15 on: June 01, 2016, 05:59:24 »
Hello, Roland. I have an early 43-86 with an Ai ring. i tried putting that into the 43-86 C version and it just would not work and I risked cross threading the Ai ring. it looks like the tolerances inside are not the same. I overhauled them both and the mechanism that holds the pin from the aperutre ring is a bit different. :o :o :o (actually, there are many improvements mechanically in the C version, i will show them in a future article)
« Reply #16 on: June 01, 2016, 10:39:43 »
Interesting ... according to the AI conversion charts from Nikon, the same three AI rings are for all 43-86mm lenses from 438601 - 774070 which covers all the early types. It only changes when you get to the New Nikkor/K version at 774071.
« Reply #17 on: June 01, 2016, 10:55:53 »
I will check that. I think mine might be the K version because it has a black front.  :o :o :o
I was intending to salvage the aperture ring and sell the donor lens  ::)
« Reply #18 on: June 01, 2016, 17:30:46 »
here they are  :o :o :o
« Reply #19 on: June 01, 2016, 17:33:18 »
OK, the aperture ring transplant is a success. The internals looked the same as far as I can see :o :o :o
i did not open the Ai one, just peeked inside. ::)
« Reply #20 on: June 01, 2016, 22:20:40 »
Yes, definitely the 6-element version here, in pre-AI and AI mounts.
« Reply #21 on: June 01, 2016, 22:24:28 »
The AI lens on the left is the newer 5-element version, with the 6-element version on the right.
The newer lens is a little longer and the DOF scale is level with the focus ring, not under it as with the 6-element version.
Also notice the focus scales, the newer has a much shorter focus throw, the first distance after infinity is 2m, compared to 5m for the older lens.
« Reply #22 on: June 02, 2016, 03:35:03 »
Wait. I was replying to the wrong topic :o :o :o
No glasses and a tiny iphone screen dont go along very well
