Author Topic: Nikkor 8mm f/2.8 question  (Read 9331 times)
Re: Nikkor 8mm f/2.8 question
« Reply #15 on: May 07, 2016, 06:32:52 »
The gap is where the front cap screws in...
Oops...Right you are...I'd forgotten about the massive screw-in cap.
« Reply #16 on: May 25, 2016, 12:04:21 »
On a side note - Notice that the front and second elements are seated on small O-rings - This is also the case of the 6mm 2.8
« Reply #17 on: May 25, 2016, 12:09:14 »
The two lenses are also different, on one of them it's only the front part of the ring that is stripped from black on the other lens it's the whole ring except the holes for the lens spanner.
Edgy01
« Reply #18 on: May 31, 2016, 23:07:42 »
A friend of mine and I collected these for awhile and then sold most of them.  Never saw this silver feature on any of them.  Our serial numbers ran from the early non-AI 240xxx to 242xxx, to 246xxx, to 247xxx AIS.
Dan
Wally
  • X-Man breaking bad
« Reply #19 on: June 10, 2016, 03:05:13 »
A few test shots from my new addition  8) Another learning curve has started...
PedroS
« Reply #20 on: June 10, 2016, 13:59:37 »
How difficult in this particular lens is transforming a non AI to an AI one?
« Reply #21 on: June 10, 2016, 14:02:25 »
Wally, I am certain that you have fun using the lens!
« Reply #22 on: June 10, 2016, 14:08:00 »
Been there - solved by getting the AI conversion kit for the 6 mm f/2.8 (Pacific Rim Camera, around $20). Fitted perfectly.
PedroS
« Reply #23 on: June 10, 2016, 14:11:47 »
Thanks
